When the machine goes in the spin cycle it makes a loud banging noise.
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 22, 2011
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
May 02, 2013 | Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
My LG Intellowasher M-1480FHD has started making a loud banging noise on the final spin. It also wouldn't end the spin cycle at the end of the 30min wash
the banging noise while in the spin cycle will more than likey be worn shock absorbers and will need replacing.
Aug 31, 2010 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
