Question about Dishwashers
I have a Maytag MDB4650AWW. It appears to have water flowing to it and good pressure but for some reason the jet arms are not spinning and therefore the dishes are not as clean as they should be.
  • 55 Answers
This normally means the seal has failed. YOu can purchase the seal and bearing kit to fix the issue. This is the part in the middle of the motor that threads in. The old style was plastic and the new is metal. You can look at a parts diagram in the link below, just plug your model number in to look.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
The drum stopped spinning, but could still hera motor running. The door was locked; could not unlock to open. After several attempts of unplugging/replugging door could be open.
Is this a dishwasher or a washing machine that you have a problem with.
The drum is usually in a washing machine. The motor you hear running is the drain motor. So this is a normal operation of front loading washing machines. When the drum stops spinning, the drain pump takes away the remaining water and then a timer lock comes into play to make sure the clothes are settled dowm before you can open the door.
So I do not see there is any problem. Please accept the solution if ok else post a comment to confirm the exact problem with your appliance.
Mar 21, 2011 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
GE Profile PDW9880 rinse arms don't spin
Check spray arms again to see if the very end jet is blocked - or if the spray arm has split? the end jet is angled and that's what turns the spray arm. If you can't clear the blockage, you may need new spray arms. Or try putting the spray arms into a known position, and run the machine - see if they have moved.
The pump may be running, but are you sure it's pumping? sometimes bits of broken glass or pot get into the pump chamber and strip the rotor vanes off. Try setting the machine to wash, make sure you can hear the pump run, then quickly open the dishwasher door to check the flow. If you get a face full of hot soapy water then everything is ok!
Remember that a dishwasher isn't a garbage disposal unit - and remove all food scraps from plates before putting them in the machine. That's what often blocks spray arm jets.
Jan 30, 2018 | GE 24 in. Profile PDW9880JSS Built-in...
Kitchen Aid Dishwasher Model KUDJ230Y3
You can try a few things to identify the problem.. first off... when you reinstall the cleaning arm..can you manually spin it freely? No binding or anything obstructing its path? If that's OK.. then you may not be getting water into the arm from it's feed. Many dishwasher arms rotate when water pressure is present.. You can verify you have water pressure by cheating the door interlock and cycling the system .. ( be careful.. since water will jet out pretty quickly) . If you don't have water pressure to the arm, chances are you have a bad or clogged pump, pinched or clogged hose from or too the pump.. Hope that helps...
Aug 08, 2008 | Dishwashers
Dishwasher appear to be clogged
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 07, 2007 | Maytag MDB7100AWB Dishwasher
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Lower arm won't spin
the arm only rotates with water shooting out of the angled jets at the end of the arm and these are probably blocked ( i assume it is free to totate manually) take the arm out and run water into the centre hole and this will help push whatever is blocking it to a visible position - usually rice or sweetcorn. you say there are no obstructions in arm but when no water flowing, the blockage tends to slump back into the main body of the arm and out of sight
May 20, 2007 | Maytag 24 in. MDBS661A Built-in Dishwasher
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
