Question about Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher
Kenmore Dishwasher takes excesive amount of time to run, and dishes are not that clean and dosent seem to dry very well
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Posted on Mar 24, 2011
My 17352 Kenmore dishwasher runs for an hour or more. Can this be adjusted?
There are wash, rinse, and dry cycles that all take time. Cycle settings allow you to vary this. For example, potscrubber mode will take longer than normal wash. You can opt for no heat drying to shorten the cycle, but then the dishes will be wet and can have possible spotting. Experiment with the controls and find the settings that give you the results you want in the least amount of time. But just FYI, an hour isn't that long for a dishwasher to cycle - many run longer than that.
Nov 03, 2016 | Kenmore Dishwashers
Dishwasher leaves a white residue
it may be caused by what you use to clean the dishes try another brand or type.
also, if the dishwasher cleans poorly, check these things:
http://www.repairclinic.com/0088_9_1.asp#Level1_2
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
I have a kenmore dishwasher. I had it checked out by service and there is nothing wrong with it however it leaves a white film on my dishes. What can i do to stop this?
You may try a different detergent, and this may give you some relief. What works best, in my opinion, is to use the least amount of detergent that you can, and still get the dishes clean. Cut the added detergent in half, and go downwards from there. We are currently using ~25% of the recommended amount, and the dishes clean up very well, with no residue.
Rinsing excess food off of the dishes prevents the soft food disposer in most new models from being overwhelmed, and will increase the overall performance of your machine over several cycles.
Also, using a good rinse agent will help, as will opening the cabinet door after the drying cycle (while still warm), allowing the dishes to continue to air dry.
Hope that this gives you some relief.
Best regards,
--W/D--
Jan 20, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a model#110774191 portable dishwasher(kenmore) it is not cleaning anything properly on the top rack. The water pressure seems good I have tried running vinegar through it I also use jet dry, I have...
the upper arm is blocked?and needs taken out and cleaned its very easy to do just pull out the top drawer and the arm will litterly pull off give it a good clean and it should be ok,also make sure the filter at the bottom is clean.adrian,,,,,,,,,,
Aug 17, 2010 | Kenmore 17248 Silver Steel Free-Standing...
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Mar 17, 2009 | Kenmore Dishwashers
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore dishwasher has never cleaned dishes
make sure you are getting plenty of water. Start the D/W without putting soap in disp. run for about 1 minute, Make sure there are no suds inside. If there is, run full cycle to get excessive amount of soap out. If no suds check in pump resevoir to make sure its not clogged.
Jan 05, 2008 | Dishwashers
Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
104 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
