Question about HP Computers & Internet
'HP Photosmart C7100 All-in-One' does not scan pictures, slides, etc directly to computer.
  • 4 Answers
Hey, have you tried uninstalling and reinstalling you software and drivers for the device?
Posted on Aug 03, 2008
HP PHOTOSMART c7100 pumpengine dont start
the service station and carriage is faulty and needs to be repaired or replaced. take the printer to a hp repair center for a technician to have a look at it.
Nov 10, 2013 | HP Photosmart C6180 All-In-One InkJet...
How to use my hp photosmart C5280 All in One scanner unsing mac leopard
When you install the Full Feature software for your printer, you receive the HP Photosmart Studio imaging software and the HP Utility printer management software. You can use either of these programs to scan, and can create custom settings in both.
In general, use HP Photosmart Studio to scan pictures if you want to edit them to adjust color, crop, remove red eye, etc. Use HP Utility to set up scan tasks you use often, such as scanning to a certain folder or software application, or attaching the scanned item to an email. If your printer has a display, you also use HP Utility to designate which scan tasks should appear on the printer display menu when you start a scan from the controls on the printer.
Make sure that the printer is connected to the computer. Turn it on. Place the item with the print side down on the scanner glass.
Use HP Photosmart Studio to start a scan: Click the HP Photosmart Studio icon in the Dock. Click the Scan button. Select your HP product in the Device Name list, if necessary, and then click Continue. From the Scan Profiles screen, click either Pictures or Documents. Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. Click Scan. When prompted, select Yes or No to add another page to the scan. The scan preview opens then click Return to close the preview and save the scan. Type a name for the scan in the Save As box. Click the Format drop-down list, select the file format you want, and then click Save.
Dec 10, 2010 | HP Photosmart C5280 Printer
Ok i bought an HP Photosmart B209 but how can i scan a picture into my computer?
You can use the program that comes with the printer. Its called HP Solution Center. There you can view your printers status, etc.. In addition you can choose to copy, scan or print files.
May 16, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
"no scan options"
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
Mar 27, 2010 | HP Photosmart C6280 Printer
HP Photosmart C7100 - only 10% of page printer
If your printer does not print the entire page, it is probably because the print head is clogged. Try going to print preferences and locate "maintenance". Find the "clean print head" option and click on it. Follow the instructions. You might have to do it several times, and that will use a lot of your ink, but it might do the trick!
As for the "printer can't get calibrate", that is refers to your print head. That has nothing to do with your cartridges, as they are just tanks with ink in it. Check this link, might help:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153777&prodTypeId=18972&prodSeriesId=1153777&objectID=c00721373
Mar 08, 2010 | HP Office Equipment & Supplies
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
Hp Photosmart C7100 All in one series. Error message on printer screen, saying Okc18a0101. cannot Print/scan/Fax etc. What do i do please?
Do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
For me it works!!
Jun 14, 2008 | HP Office Equipment & Supplies
Negatives to pictures
The manual didn't show negative and slide support. I recommend you some of the hp products like HP Photosmart C7180 All-in-One, HP Scanjet G3010, HP Scanjet G4010, etc.
Feb 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
