Question about Euro-Pro F2015L Deep Fryer
The fryr does not get hot enough to fry anything,and i got the warrenty,when i bought it at lowes
  • 604 Answers
You have the warrenty, simple. take it back to lowes or better yet call them first, if you bought the extended warranty, you may need to call a special phone number, but you could start by calling Lowes, they are easy to deal with generally.
Posted on Mar 22, 2011
How much grease for frying and do you lock the Lide whenfrying fish
You need enough grease to cover the fish, and NO don't lock anything when you're frying anything -- ever.
Jan 19, 2018 | The Office Equipment & Supplies
Screen is black
sounds like it was enough to pop something in the tv, smell the back of the tv smell if anything smells burnt or hot. unplug the tv and let stand for about a hour unplugged then trying it again but if it does smell chances are you will have to see if your still under warrenty and have the unit replaced.
Aug 09, 2008 | Mitsubishi VS-50605 50" Rear Projection...
FRYER DOES NOT STAY HOT ENOUGH
You probably will not like my solution.
Either get a fryer with more BTUs or put less in it. You might be able to partially pre-cook the tater tots and or fry's then you only will only need a few minutes to fry them and your heat should hold. If the heat holds they should no longer be greasy (Oily) when finished.
Apr 07, 2014 | American Range Kitchen Appliances - Others
I have an xbox 360 game that does't work I bought it six months ago can you help
you are not detailed enough sorry. But if it is something like not turning on, your power supply might be fried or it has bad connection between the motherboard and the power supply. If you xbox's right is red, it is best to have a technition over or send it to microsoft. you should have and 1 year warrenty if it is 6 month old!
Jun 30, 2011 | Microsoft Video Game Consoles & Games
I have a whirlpool gas stove, professionally converted to propane and it"s cooktop doesn't cook hot enough when frying, it doesn't crisp the surface I don't think the burners are burning at the correct...
Have them come back and check the gas pressure... either the tank regulator or the stove regulator are running at too low of a gas pressure... for propane it should be at least 10" WC...
heatman101
Aug 31, 2010 | Whirlpool Kitchen Ranges
8n (front mount distributor)seems to be frying coils, one day working just fine, next doesn't spark at all, New condenser, plugs, wires, rotor,points, distributor cap. Replaced coil last time seemed to...
Had the same problem, but was my fault for bypassing the ballist resistor (my bad). Anyway, I fried the coil. Read all the posts and bought new 12 volt coil (it has been converted before I got it 13 years ago). New points, condenser, cap, rotor. Now it is just my timing is a little off, but I have strong sparky but not enough to fry my coil again.
If anything, keep the ballist resistor. it is needed to drop the voltage to the coil so it doesn't fry.
Jan 12, 2010 | Ford 8N Tractor
Evap coils frost up for about the first 4 inches then no frost any further
This could be a low capacity compressor issue (It can pump the coolant down far enough to make it cold again. Or perhaps your coils in the back or under the machine are dirty and not able to dissipate heat. The last thing is that it could be low on coolant. If this is your main fridge, call a tech to take pressure readings to see if the coolant is too high or too low. Clean the coils in the meantime and see if anything changes.
Oct 30, 2009 | Amana ABB1927DE Bottom Freezer...
I have a home theater setup bought from Best Buy. The receiver is a Denon AVR1908. It seems that after its been on awhile and gets warmed up the sound goes awful. The speakers start crackling and it gets...
if your warrenty is still valid you should return it an get another one, sounds like the reciver has a problem internally witch is bad, it will get so hot that it fries the wires an could damage the parts in side somthing isnt working as should
Oct 22, 2008 | Denon Audio Players & Recorders
Did I fry it?
hi hamstermann,
Fried like bacon is about all I can say.
Thats alot of volts going through something like that.
Not sure what a 7000 series costs,
but hopefully you have warrenty to cover it.
Just between you and me, dont tell them you messed up the cord.
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
Euro-Pro F2015L Deep Fryer Logo
41 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
