Hello. I have a LG 47lg50-ua that when turned on, the right half of the screen goes white. The left half still plays fine. The warrenty had just expired so. I took the back of the tv off and looked around. I noticed that the top left ribbon cable (looking at the TV from the back) attached to the T-Con board (a CMO 35-D020223) had puffed up a bit. I took the bad ribbon cable out and put the good ribbon cable on the bad side. After the TV was turned on, the right side of the TV stayed white and wouldn't give a picture. I looked at the ribbon cable and it was beginning to puff up so I turned the tv off. I would like to know if the TV is fixable and if so, what parts I would need to fix the TV. Thank you very much, Joseph
    Sergeant:
    Champion:
  • 285 Answers
If you changed the Ribbon cable and its still the same then the T-Con board would of probably gone faulty. Lots of weird screen problems can be accounted for the T-con board.
Posted on Mar 22, 2011
LG model 55uf6450. TV turns off and get static with left half a side of magenta. Audio is white noise. What is wrong?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 01, 2017 | LG Televison & Video
LG 47LG50 has no picture.
T'Con board fault. Check and replace it. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 02, 2017 | LG 47LG50 47LG50 47-inch 1080p LCD HDTV...
OK.. it seems i'm not having a lot of luck with TV's these days.. i have a LG 60PS60-UA plasma TV that won't power on. when I do i get a red light where the white light normally is when working corre
Hi, It also could be the inverter board(s) that have gone bad. Check them out. If the inverter board goes it will also turn the TV off.
These boards are on the left and right sides of the TV pannel.
Good Luck with your repairs.
Dec 19, 2014 | LG Televison & Video
Lg 47lh40
Check its connection between LCD pane and T'con board for any loose contact.
Apr 28, 2013 | LG 47LH40 47 in. LCD HDTV
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
LG 47lg50 white screen no buttons responding
A white screen with nothing else leads me to believe you have a problem with a t-con board or a signal board on that TV.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | LG 47LG50 47 in. LCD HDTV
On/Off Button on TV not working, constant flashing message
www.lg.com/us/tv-audio-video/pdf/47LG50_spec_sheet.pdf
http://elektrotanya.com/lg_lcd_tv_la84a_mfl41370007_47lg50-ua.pdf/download.html
Above user manual top, below is your service manual, perform the troubleshooting procedures and you should be able to localise your problem.
May 13, 2010 | LG 47LG50 47 in. LCD HDTV
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
I find the top screen goes white when its moved about its fine when playing steady games when it goes white i just move the top part and it works fine maybe some ribbon or lose connector this is on a...
hello, yes it sounds like the ribbin connection the top screen (also video and power) may have a fine break on one of the fingers,
You can try find a broken one and repair it or bring to a games console repair agent.
you could also return it to the store if it is still under warrenty.
Hope this helps...
Feb 20, 2008 | Video Game Consoles & Games
Televison & Video Logo
273 people viewed this question
Top Televison & Video Experts
