Question about Weber Q Grill
Very low flame, can not see it burning bu feel heat
    Brigadier General:
  • 4,736 Answers
The Gas line Regulator to the tank is probably locked up. Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the tank vale is fully open try lighting the burner and turn it to the highest setting. Do the flames look as they should? If so, you solve the problem. If not, are you sure you have enough gas in the tank to sustain the burners on high? If the gas level is Ok, then you will need to replace the Hose/Regulator Assembly, as the regulator has gone bad. You can purchase one at any home center or hardware store that sells gas grills. Take your old one with you for comparison purposes.
Hope this helped you solve the problem.
Posted on Mar 22, 2011
  • kebmod54 Apr 02, 2011
    Important when lighting a Q model, only open the tank valve a 1/2 turn, wait a few seconds, then ignite the grill. After it is lite, then open the tank valve the rest of the way. If your Q still has a low flame, you can also remove the burner and clean it very easily.
When burning on low the bottom corners have a blue flickering flame and it gives off a propane smell
A blue flame is good, but depending on the heater there should be no smell. As I am sure you know, Carbon Monoxide is a great hazard. Any fitted flame heater should have adequate exhaust ventilation. You should also have carbon monoxide detectors on all levels.
Nov 25, 2017 | Heating & Cooling
Is all 3 burners supposed to burn even on low ? And does the heat cut on and off ?
doubt they all burn except on high low will be 1 med will be 2 and HI all 3 . unless it is controlled by a thermostat the flames do not adjust automatically .
Dec 20, 2016 | Kitchen Ranges
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
My fire burns with an orange flame and is either on full heat or low heat, no inbetween so can't ajust heat properly, can I fix it myself and if so, how.
Don't know whether you can adjust to somewhere between low and high. However, the flame colour that you describe seems a bit off. I would have expected it to be bluer. The air/gas ratio might need adjusting and before you ask, I have no idea!
Jul 09, 2015 | Heating & Cooling
Propane wall heater
Clean pilot , Then check thermocouple if it is not staying alight .
May 03, 2017 | Heating & Cooling
Rg(bu)h-07eauer have replaced the control board will not heat
read wiring and make sure flame sensor is clean and make sure you have good ground
Oct 16, 2009 | Heating & Cooling
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
My gas dryer puts burn marks on my clothes. I only use low heat
The flame is too high or the heat sheild is defective. The flame is too close to the drum!
Mar 26, 2009 | Frigidaire Dryers
Will turn off after 1 min run on low heat burn
Hi Billie,
You didn't mention the model number, but they are all pretty basic. The flame sensor and thermo pile which are thin flame sensors, get charred and need to be cleaned. They should be cleaned with a soft cloth or even a dollar bill will work (a worn one)
When the heater shuts down it usually means it is not sensing the flame and this will cause it to shut off automatically. I have included a link to get the owners manual below.
Good luck and be sure to turn off the gas and power to the unit before working on it.
Click Here to Get Owners Manual
Thanks,
Paul
Jan 18, 2009 | Desa International GWP20T GLOWARM Wall...
Weber Q Grill Logo
152 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
