Question about Acer Veriton 7600GT PC Desktop
Power not on
When swith on the power button nothing happen.
Your assitance very much appreciated.
Thanks
    Novelist:
    Scholar:
  • 125 Answers
  • First if you have move the computer recently, check that nothing has moved inside box and unplug cards if any including memery and replace again.
  • Check switch if working, does it turn on if you hold button? If so New switch required.
  • Most common problem: Power supply might be blown, see if the fan is running in the back of box when you start-up. Otherwise you will need to check a few things before you replace with new one. Check that the CPU fan inside box is running. Check that there isn't dust build up on fan stopping from running. Might need replacing. Try also taking out battery and starting up computer. If all else fails you will need to replace power supply with a 500watt or more power supply. If you have another computer on hand, you could try the power supply from that system as look as it has same connectors and try and run with that. If works then you know what to do. If nothing, the motherboard might be gone, or cpu even. Try also taking memory out and replacing. see if runs.
  • Before you give up, unplug all cables to hard drive, cd roms and DVD-rom and try to turn on
Posted on Aug 03, 2008
Acer ferrari won't power up
Seems like you have a dead battery AND now a broken power cord.
Just in case, remove battery and power cord and hold the power button down for minute.
Apr 04, 2014 | Acer Ferrari Computers & Internet
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
I swithced my fone off and im trying to swith it on and it just doesnt swith on wah am i meant to doo!
when you turn your phone on only the keypad lights up right? or nothing happens?
if nothing happens charge your phone til red led on side turns off
after that please continue to read
its a w980 software problem, very common
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
please note this will restore phone to factory state
Nov 16, 2009 | Sony Ericsson Walkman W980i Cellular Phone
Toshisba laptop wont swith on tried swithing a charger and battery still no change nothing happens
If you have tried a new charging cable and a new battery that kind of narrows it down to the power button being faulty.
Aug 30, 2009 | Toshiba Satellite Pro L300 Notebook
I can't swith my Acer laptop on. There is a yellow
REMOVE THE BATTERY AND ALL THE POWER SOURCE IN 20SEC THEN POWER IT AGAIN BUT YOU HAVE TO PRESS THE POWER BOTTON IN 3-5SEC.IF NOTHINGS HAPPEN YOUR UNIT ARE TOTALY POWER DOWN IT'S IN STANDBY MODE
Aug 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
EMachine 2862 Desktop Dead On Power-Up
check all the leads to the hard drive and check that the fan starts spinning when you switch it on if it dont start then the problem is the switch these do often go and can be easily replaced and they are not expensive i had the same problem and found that it was just the switch hope this solves your problem for you you can bypass the swith so that the computer comes on when you turn the plug on but when you shut down the computer this shuts everything down but the switches are cheap enough to buy if you have changed the power pack then the only thing it can be is switch .................................
Oct 31, 2007 | E-Machines T2682 (000002965) PC Desktop
Tv will not power up.
Silly question but, did you try to reset the TV by unplugging it for 2 minutes then plugging back in? Its worth a shot if nothing else.
Feb 01, 2007 | JVC AV32F476 32" TV
Acer Veriton 7600GT PC Desktop Logo
248 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
