Question about RCA L26HD31 26 in. LCD HDTV
The TV would not stayed turned on. Then the screen made a popping sound. Now my RCA L26HD31 doesn't come on at all. Is it fried, or is there a part I can replace?
    Sergeant:
    Champion:
  • 234 Answers
I would start with finding online and replacing the power board.
Posted on Mar 22, 2011
Rca l26hd31 no sound no picture
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
Nov 02, 2012 | RCA L26HD31 26 in. LCD HDTV
Canhearsoundbutnoscreen?
your lcd hard damage. can use no problem.
May 28, 2012 | RCA L26HD31 26 in. LCD HDTV
Cannot connect my pc via hdmi to an RCA L26HD31. TV registers unusable signal. Is the set bad, or did this model not support hdmi from a pc?
If your trying to use a computer with a video card that is not HDCP capable it will not work.You'll need to replace the video card that has hdcp .You can thank Hollywood for that.Hope that helps
Apr 27, 2011 | RCA L26HD31 26 in. LCD HDTV
This RCA L26HD31 TV has always worked fine in other respects... but when I try to connect my pc's hdmi cable to it for use as a monitor, I just get "unusable signal". When this TV was made, hdmi...
Make sure you have set the laptop's display properties to as low a resolution as possible (also make sure the screen refresh rate is 60 hertz) and turned it off before connecting it to the television. Turn the television on first and set to the correct input either hdmi 1 or 2. Then turn on the laptop. When it has booted up hold down the function key and the dual monitor key (either F5 or F8) for 15 seconds for an image to appear on the screen. When you have an image you can play around with increasing the laptop's resolution.
Have sound but no picture
inverter board has failed try shop jimmys on the web
Sep 16, 2009 | RCA L26HD31 26 in. LCD HDTV
My daughter dusted our lcd tv and now there are dark spots on it. can this be fixed or do i have to buy another tv?
If she pushed hard on the lcd and these are now dead pixels i am afraid you need a new LCD screen at thi point.
It would be more cheaper if you just got a new lcd screen verses buying a new TV/
thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | RCA L26HD31 26 in. LCD HDTV
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
RCA L26HD31 26 in. LCD HDTV Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
