Question about Garden
We are looking for a manual for it in case anything goes wrong with it.
83 yz 125. Split cases to find shifting problem. Can't see anything wrong. No broken gears, forks look okay. Can anyone give me tips on the next step?
does the selector drum rotate ok and is the gear selector shaft that the gear lever goes on straight and not tight in the crankcases.and have you checked the bearings on the input and output shaft are good.
Jun 13, 2015 | Motorcycles
My machine will not sew. New not used but a few years old. once thread goes down to bobbin it locks and you can hear the clutch disengage. without thread you can run the needle at full speed then it
There may be a small bit of thread or lint caught somewhere in the bobbin case or bobbin holder. Brush lint away from the feed dog area, being careful not to brush lint into the workings of your machine. If you have the manual, look up how to clean lint from the bobbin. If you don't have the manual, try just taking the hook out, if possible. Run a clean toothpick around the housing and then use a clean small brush to brush out any lint or thread pieces. Put one drop of sewing machine oil on the hook of the bobbin housing. Then use a thread to "floss" your bobbin case. Run a thread through the slot and wiggle back and forth to loosen any caught thread bits. Good luck. ps If this doesn't work, repeat. Sometimes after you turn the hand wheel a bit, another piece of thread or lint will work loose and can be cleaned.
Dec 06, 2014 | Sewing Machines
Wont sew.tread won't connect what's wrong?
I think you mean that the feed dogs are not moving the fabric under the foot and through to the back of the machine. The feed dogs have settings for different elevations. Look in your manual for this adjustment. Feed dogs are the "grippers" under your sewing machine foot. Another issue may be cleaning. When anything goes wrong with your machine, stop and clean it. Most problems can be solved with a good cleaning. Don't forget to oil according to the manual directions as well.
Oct 20, 2014 | Sewing Machines
Can i replace inbuilt speaker for Compaq presaria c700??
It looks feasible, but complicated. It may be easier to use external speakers, or have a professional that will take responsibility if anything goes wrong.
http://www.hp.com/ctg/Manual/c01301275.pdf
Oct 01, 2012 | Compaq Presario C700 Series Laptop...
CANT PUT IN TAPES
I assume you mean when there's no tape in? This sounds like a possible mode switch problem. This device tells the electronics of the VCR which position ie: play/fast forward/eject etc - the mechanics of the machine is in. However it's only a complex switch and contacts wear or get dirty, so the whole thing goes wrong! What you need to do is find this part (I will post two images of what it might look like) and spray it with Servisol Video 40. This will get rid of dirt. It won't do anything about wear though. In which case it will need to be replaced. However you will need a service manual if that is the case. As you will never be able to set it up right. There's one more thing to add about the mode switch, it can go wrong if something has broken and the mechanism is out of sync. In which case it will be working, just in the wrong start position.
May 15, 2010 | Televison & Video
TLK3 T3 Motorola permanent static noise
The "MONITOR" is probably stuck on. You can go to
http://www.mods.dk/manual.php?brand=motorola and login (its free) and download the manual and look for how to turn off the "MONITOR" function.
Nov 02, 2009 | Motorola TLKR T5 Two Way Radio
Bought a used trim mac 250 in really good condition. works well but came without manual/instruction book. Can u tell me where I can download one just in case anything goes wrong
I checked on google on the trim mac 250. I found the fifth selection down for a site to find an operating manual for. it thats does not work try Diplodocs.com.
Oct 06, 2009 | Garden
Machine not working after bobbin installation
Hi, it may be possible that you put the bobbin in the case upside down and its turning the wrong way. Flip it over and try it. When looking at the bobbin in the case from the back and you pull the thread, it should turn clockwise.
Hope this helped as anything else may take a tech to diagnose.
Rick
Mar 21, 2009 | Bernina Virtuosa 150
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
