Question about GE Refrigerators
Refrigerator and freezer not cooling enough ever since we had a city wide power outage. We turned the temp controls to 9. I am an electrician experienced in troubleshooting. What should I look for before replacing the $150 mother board?
  • pcjackson50 Mar 22, 2011
    No clicking sound or frost on back wall of freezer
    GE frig model #GSH22KGMDWW the frig is at a rental house - I'm not on site and I haven't been able to pull the frig out yet because we have to take some trim off to get it out. I was hoping for a list of things to look for when I do get there to work on it
  • 4,070 Answers
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
The other cause and type of frosting is automatic defrost failure.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Mar 22, 2011
    Sergeant:
    Champion:
  • 202 Answers
Do you hear any clicking at the back or is there frost in the freezer at the back wall??
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Refrigerator cool freezer not as cold as it should be
try turning of the frige and let it be of for 1day then put back on and see if will works usally does,if not next usally is the compressor does give enough cold.motherboards dont go bad usally very rare,check all the above before you buy motherboard.please leave comment,vote,note.thankyou
Sep 13, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ref has no power
First thing to do is to make sure that the plug is hot that your refrigerator is plugged into. Most of the time it's a gfi and it may need to be reset. if youi don't see it there sometimes the electricians will pu it in the garage and or the bathroom but it is still on the same circuit. Hope that htis helps you out.
Dec 25, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
