Question about Hoover Refrigerators
Freezer had stopped working unplugged it looked at the back freezer motor starts for a second when you plug it back in then stops tapped the motor plugged it in again and it worked until yhis morning whrn a fuse blew in the extension lead now it wont start again
    President:
  • 1,462 Answers
Take cover off compressor electrics and check in good order - maybe relay or starting device burnt out
Posted on Aug 03, 2008
Unit not cooliing, all the fans are working and unit is clean
The click sound might be the motor trying to start. If it has problems tou have to replace it.
Feb 10, 2014 | True Manufacturing Countertop Glass Door...
Frigidaire side by side refrigerator and freezer not working
Hi on most cases if your freezer or fridge stop working correctly at some point by not cooling or freezing right. It my be backed up by ice in your unit. which will prevent your fridge from venting or draining on to the pan. I think the condensor or little look alike radiator will be frozen up. Most cases the drain area will be back up with ice preventing your freezer from working properly. Need to remove items from freezer and try to fix it by adding warm water to the drain area or call a profesional for help
Dec 04, 2013 | Frigidaire Refrigerators
Whirlpool freezer which is non frost is making ice and freezer stop working
I would first unplug the freezer, let it thaw, and then plug it in to see if the motor kicks in. If that is to no avail, then you could be looking at a bad motor.
Mar 09, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
Sudenly stops working everything in freezer thaws out and refridgerator goes warm,the lighhts are on and the fan inside the freezer is blowing warm air.if i unplug it and it sits for a few hours and then i...
The auto timer in your Fridge is faultly and is not defrosting in the eight hour cycle. There could also be any wire detached from corrosion inside/within the freezer compartment that gives wrong signals to the the thermostat. You will have to remove the inside cover to confirm.check the wires to the heater/ failure of the heater. In case you are not able to do the work have this in mind and look into what the technician responds. take an estimate and move on.Helpful? good day
Jul 02, 2010 | GE GSH25JFR Side by Side Refrigerator
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer stopped working. Unplugged and plugged
The compressor trying to start and not getting started...it could be mechanically broken or the start cap and relay could be bad...
here is a tip that will help you with that...
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Feb 22, 2010 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Motor seems to have shut off...
You most likely knocked a wire or part loose. Unplug it, remove the cover and search for loose or disconnected wires or any hanging parts that should not be hanging.
Aug 30, 2009 | Whirlpool GD2SHGX Refrigerator
Shuts down, interior lite on tho, plug back in and works - stops
You have a bad thermostat ( the piece where you adjust the coldness of the refrig ) . Once it gets to temp and shuts off , it will not tell the system to start again . Next time not running , tap on the t-stat . If it starts , this tells you the thermostat is bad .
Aug 25, 2009 | Avanti 651WT Top Freezer Refrigerator
Kenmore Elite Trio 596.76529500 It makes a
It is the Freezer Fan, he ice maker fan. I experienced the same conditions of a two year period. The tech allows said either unplug overnight. I as you couldn't take the noise. Oh by the way it will be getting worse!!! The solution replace the Freezer Fan motor.it cost about $78.00 plus shipping. they are located behind the freezer rear wall. They are very labor intensive to replace because the electrical leads are attached just out of reach. I have a 33" arm and I had to act like a contortionist to unplug them.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Back wiper stopped working on my 2002 buick revdezvous
better if you look for a fuse, i work on them and never heard of a reset button,lol. make sure arm is not slipping on shaft and motor is really all the way stopped, if fuse is ok the mostlikely cause i have seen is the motor, you can pull down the back panel and turn on wiper and tap on motor to see if it starts taking off, this may or may not work but worth the try, if does not work unplug the wire to the motor and put a test lamp on the positive and negative sides to see it the power and ground is getting to motor but i would suspect your looking at a motor.
Dec 27, 2008 | 2002 Buick Rendezvous
Refrigerators Logo
135 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
