Question about Polaris Pb4 - 60 Booster Pump
I am replacing an old booster pump with a Polaris PB4-60. I have three wires, One Red, One Blue, and One Green. Now I know the Green is Ground, but which poles do the Red and Blue go? Both seem to say "Load" coming out of the timer box.
  • 310 Answers
It is impossible for us to know what voltage you are running as you did not list that information here.
Typically a green-red-blue comination of wiring suggests 240 VAC connections.
Also, every motor you buy is required to have a wiring diagram on the side of the motor. This should tell you where to connect the wires.
IF you are running 240 v as suspected, both the red and blue wires are "hot" wires on the load side of your timing box. Simply look at the side of the motor and follow the diagram on wiring the pump.
Typically most motors in the USA use a L1 and L2 terminal to connect the 2 "hot " wires.
This pump does come factory wired for 240 volts, so it probably is just 1 each of the "hot" lines to L1 and L2.
Before connecting, make sure you confirm your systems voltage with a multimeter.
Below is a link to the installation manual for this pump. But it does not list electrical diagram since its on the side of the motor.
http://www.clubp.info/pdf/TL/P-134.pdf
Posted on Mar 23, 2011
How do I wire a Polaris PB4-60 in the USA (115V)?
if 120 volt see schematic must move the brown wire and white wire then black or colored on L1 then white on L2 then green ground to case
Jun 20, 2014 | Polaris Pb4 - 60 Booster Pump
Pool pump wires blue, white, green
check to see if between the blue and white 120 volts if so see side of pump motor for low voltage wiring(120volt) have to move the brown and white wires then blue to L1 white to L2 with other white green to case or ground
May 11, 2014 | Polaris Pb4 - 60 Booster Pump
Installing replacement Polaris booster pump pb4-60. Removed old wiring without checking to see what went where. Dumb. incoming wire has a red, black , white. What goes where?
if 220 volt either red or black to l
1 the other to L2 white to ground or case make sure to measure between red and black you should get 220 volts ac
Aug 01, 2013 | Polaris Pb4 - 60 Booster Pump
My power supply has 3 wires, red, black and white. Pump wiring diagram has 6 posts for 1 yel w/blk, 2 brown, 4 black, 5 orange white 6 yellow. There is no red. what goes where?
see side of motor check voltage between red and black should be 220 red and white 120 volt black and white 120 volt make sure wiring is still for 220 from factory black to L1 red to L2 white to ground make sure white in box goes to green bus
Aug 01, 2013 | Polaris Booster Pump and Motor 34 HP
Incoming wire has red,black,white. What goes where
One of those wires should be green (ground wire). The two wires that are not the ground wire go to the two terminal posts, either way, and the ground screws directly to the motor housing above the terminals. Should be a green screw there. Was this electrical used on a 2 speed pump before?
Wiring a Polaris 280 booster pump motor
if connecting 120 volt see side panel for wiring change from 220 to 120 volt move brown and white wires then black to L1 white to L2 then green to ground or case
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
I am replacing an older polaris pb4-60 with a new polaris pb4-60...when moving the power cord to the new pump i have 3 wires, a green, black and yellow...I know the green is the ground, but which poles do...
if across the black and yellow you have 220 volts ac then wiring from factory ok black to L1 yellow to L2 and green to ground or case if 120 volts see side of motor for wiring
Jun 09, 2012 | Polaris Pb4 - 60 Booster Pump
How to change voltage on polaris booster pump pb4-60
see side of pump motor schematic shows low (120) vs high (240) volts move brown and white wires as shown then black or colored wire to L1 then white to L2 then green to ground or case
May 21, 2012 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
569 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
