Question about Archos 605 WiFi Digital Media Player
Archos 605 WiFi stuck
Hey.
My Archos 605 WIFI has started freezing on the startup screen saying 'Entertainment your way'
It doesnt go any further, and after a while on that screen it just shuts down.
Would the reset button do it? And would i loose all my files?
Has anyone else had this problem?
Thanks!
  • 1 more comment
  • Anonymous Jan 01, 2009
    it didny work
  • crmcleod1962 Jan 02, 2009
    recovery code 102 what does it mean
  • ringowren Mar 05, 2009
    after i turn it on it goes to the 102 recovery screen as did yours but after that i push repair and it goes to the main screen saying "archos entertainment your way again for like 15 min. then back to the white screen giving me the three options again. and my computer dosnt recognize it. what do i do. just format. ive been trying not to because i have like 50 music vids and like 800 songs that took forever to get on it and get. so i need some help. if you would, please.
Mine did that the first time i opened it out the box and turnin i just pressed the reset buttion
Posted on Dec 28, 2008
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Posted on Sep 18, 2008
Broken screen
on ebay its called a New Original ARCHOS 605 WIFI LCD touch Screen digitizer
Apr 22, 2010 | Archos 605 WiFi Digital Media Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605 running Vista Computer does not recognise the archose
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
Feb 06, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
I cant access my files when I plug my Archos 605 into a computer!
i had the same problem what i did was i downgraded my 605 to
Archos 605 Wifi (20GB-160GB) OS v 2.0.10
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04
heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos
and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
Jan 01, 2009 | Archos 605 WiFi Digital Media Player
When I turn on the device the screen displays- ARHCOS entertainment yor way- and nothing else.
I found the tech support line very helpful when I first got mine last December. Some things were solved with firmware. Sounds like you might need to get it replaced and you should be well within a warranty period to give a new one a try. Good luck! I love my archos 605!
Aug 27, 2008 | Archos 605 WiFi Digital Media Player
HOW TO TURN THE WIFI ON THE ARCHOS 605 160GB
you need to buy the wifi plug in from the archos website, then unload it on to device
Jul 12, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi freezes
Mine kept freezing alot, and now the on/off button wont work. I can only turn it on with the docking station.
Jun 14, 2008 | Archos 605 WiFi Digital Media Player
My archos 605 wifi
Try reseting device by inserting a pin in the bottom reset hole. If still non-responsive, try connecting device with usb cable and switch device on then off.
All else fails you have a 1 years warranty on device, which comes standard.
May 26, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
1,016 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
