Question about Fisher Dishwashers
Installing controller.........removal of drawer panel
  • 55 Answers
You can watch a video that explains how to make this repair from the link below. I have seen the video and it explains how to remove the drawer as well as the front panel to gain access to the control assembly.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do you remove display panel from frigidaire affinity washer
Pull out the detergent drawer, pressing the catch button in the rear of the drawer. There are a couple phillips screws through the panel around the drawer. Take those out. The display panel (including the entire plastic piece) is attached by plastic clips. Unsnap them by applying firm, controlled pressure along the top and sides of the plastic panel. Should come right out for you.
Feb 20, 2011 | Frigidaire Affinity ATF7000ES Front Load...
GE #WHDVH626 Front Loading Machine - Door gasket Leaks, Need to replace gasket, HOW?
Remove the top panel, the control panel, the toe panel, and the front panel to replace the door gasket. Disconnect power to the washer before servicing to avoid electric shock.
Remove the top panel by removing the top cover and the three 7-mm hex-head screws that attach the rear of the top panel to the cabinet. Remove the top cover by removing the three Phillips-head screws that hold it in place then insert a putty knife blade or similar tool along the top seam between the cover and the control panel. Lightly tap the cover off rearward; slide the top panel rearward then lift it off the cabinet.
Pull the dispenser drawer out until it stops; push down the locking tab, and then pull the dispenser drawer all the way out. Once the drawer is out, remove the Phillips-head screw from the recess of the drawer opening.
Remove the four Phillips-head screws that attach the control panel to the control panel cover. Release the tab on the right side of the control panel from the bracket inside the cabinet.
Lift the top edge of the control panel to release the three tabs that hold its top in place. Push the control panel towards the left, then release the side tab.
Label the wires and mark the connectors matching the wires before disconnecting the wires from the control panel.
Remove the three Phillips-head screws at the bottom of the toe panel holding it to the cabinet, then pull the toe panel down and off the cabinet.
Open the washer door, then remove the three Phillips-head screws holding the door switch and lock assembly to the front panel.
The door gasket is held to the lip of the door opening by a wire and a spring hidden in the fold of gasket. Grasp the wire at the spring location using a pair of needle-nose pliers and stretch the spring to clear the gasket, and then remove the wire and spring assembly. Peel off the door gasket from the lip of the door opening into the drum.
Remove the four Phillips-head screws that secure the front panel on its four corners to the cabinet. Lift up the front panel then remove it from the two hooks and all the way off the cabinet.
Pull down the top of the gasket, and then remove the nozzle from the gasket. Remove the gasket from the water inlet pipe, and then loosen the 7-mm bolt that tightens the wire holding the gasket to the outer tub lip. Take note of the position of the gasket, and then remove it and the wire from the lip of the outer tub.
Install the new gasket into the lip of the outer tub aligning the notch in the gasket with the arrow located on the top of the lip of the outer tub, and then secure it with the wire and the bolt. Do not over tighten the wire with the bolt. Allow a gap of about 1.25 inches between the ends of the wire. Over tightening the wire may tear the gasket.
Insert the nozzle into the gasket ensuring that the washer is placed on the outside and that the nozzle is aligned with the dent on the inside of the gasket. Insert the water inlet pipe into the gasket, and then put the gasket inside the drum.
Reinstall the front panel back into position on the hooks then secure it to the cabinet with the four Phillips-head screws.
Slide the toe panel up into the cabinet then secure it with the three Phillips-head screws.
Reconnect the wires to the control panel. Snap the control panel back into the cabinet, and then secure it with the screw at the recess of the drawer opening.
Slide the top panel back in place then secure its rear with the three 7mm hex-head screws to the cabinet. Reinstall the top cover and secure it the three Phillips-head screws.
Mar 12, 2010 | GE WSXH208A Front Load Washer
I have a Whirlpool duet washer and on the control panel the light that says control locked is on and the washer does not work - is there a way to reset it?
Press the Pause/Cancel button twice then press and hold the End of Cycle Signal button for three seconds until the Control Locked light turns off. If it doesn't work, unplug the washer for at least fifteen minutes to reset it.
Replace the user interface/LED assembly if the Control Locked indicator still lights up and not allowing you to operate the washer.
Remove the three screws at the rear of the top panel securing it to the back of the washer. Slide the top panel back and lift it off the washer.
Disconnect the user interface/ LED assembly ribbon connector from the left side of the central control unit (CCU) and release it from the wiring harness brackets.
Pull the dispenser drawer out and press down the release tab at the back of the drawer to pull it out completely.
Remove the screw that was covered by the dispenser drawer in the recessed hole next to the drawer opening.
Open the door and insert a flat-bladed screwdriver into the notch at the bottom center of the control panel to release it.
Press and release the tab behind the right hand side of the control panel securing it to the cabinet.
Gently pry up and release the top of the control panel and pull it off the washer.
Pull the cycle selector knob off the control panel and release the tabs securing the user interface/LED assembly to the control panel. Lift the user interface/LED assembly from the control panel once all the tabs are released.
Install the new user interface/LED assembly into the control panel by inserting it into the tabs from one side to the other until it is completely secured.
Install the control panel on the washer and the top panel in reverse of the removal steps.
Note: Please specify the model number of your washer for the specific replacement parts.
Mar 01, 2010 | Dryers
How do I replace the control panel? Where is the
You need to remove the top panel before you can remove and replace the control panel. Remove the screws holding the top panel to the back of the machine and slide the panel backward.
Disconnect the user interface wiring harness from the Central Control Unit (CCU). Pull the dispenser drawer out and press down the release tab at the back of the drawer to completely pull it out.
Gently pry up and release the top of the control panel and pull it off the cabinet.
Install the new control panel in reverse of the steps above.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
What is the easiest way to get the front panel off of my LG front load washer to replace the large rubber drum gasket which ripped? Is it screwed on or pressure fit?
It can be changed out without removing the front panel. There are special tools designed to remove and re-install the spring clamps which hold the gasket on, but you can do it with long nose pliers or other implements. It is more difficult to do with the panel on, but it can be done. If you want to remove the front panel: Remove bottom screws from plastic parts on the back edge of the washer top. Stand in front of machine and use the palms of your hands to sparply push back the washer's top about 2 inches, then lift it off. Remove screws from support frame to control panel. Remove dispenser drawer by opening it and pushing the tab on the top back side down while pulling the dispenser the remaining way out. Remove screws from behind dispenser drawer. Release tabs along the top edge of the control panel (watch out for sharp edges) and swing the control panel up on top of the washer drum. Remove spring clamp from front of rubber door gasket. Open access door panel on lower left of front panel. Use small hose to drain out remaining water. Remove phillips head screw in recess, then use plastic putty knife to push inward on the left or right edge of rectangular housing around the recess to remove recess. Remove screws at bottom from bottom of front panel into frame (located behind plastic recess) Remove screws along top edge of front panel. Tilt front panel forward and unplug door switch. Set front panel to the side.
Feb 01, 2010 | Washing Machines
Torn gasket
Catriver(fixya) has a solution:
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torq screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. I know it sounds like a lot, but it is not that bad. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Apr 14, 2009 | Kenmore 44072 Front Load Washer
Kenmore HE 2 Front Load Washer Leaking
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torx screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwashers Logo
64 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
