Question about Apple iPhone Smartphone
Iphone won't turn on completely - the apple sign appears but it doesn't turn on, it only vibrates when I try to charge it. I tried to hold the top and home buttons - didn't work. Can anyone help please?
    Sergeant:
    Champion:
  • 234 Answers
Download a program called tiny umbrella. This program has the option to kick it out of recovery mode. But first, plug it into the latest version of iTunes and let me know what it says for error code.
Posted on Mar 22, 2011
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
When I charge my phone it vibrates but it won't turn on
You could try re-setting your iPhone. This does not delete any data on the iPhone but forces it to re-start as if you had just turned it on. Hold down the power button while at the same time pressing and holding the home button until the screen goes blank and the Apple logo appears. Now let go and it will continue to re-start as normal.
Oct 14, 2013 | Apple iPhone Smartphone
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Hey. I was plugged my iPhone into a wall charger. As soon as I plugged it into the dock it vibrated twice then suddenly stopped charging. Then again it vibrated... But only once then it went off....
have you tried holding the power button and the home button on the front together? Anything?
if that doesnt work power up your comp with most recent itunes on it and hold the home button down on the iphone and keep held down while plugging to comp and keep held until a message appears on itunes saying a phone has been detected in recovery mode, then restore your iphone as new.
if your phone is over heating then its a safety issue, see if your still in your years warrenty and if you are give apple a ring they should help you out under your limited warrenty
Jan 14, 2011 | Apple iPhone Smartphone
My iphone 3G just shut off on its own & it will not come back on when I try to trun it back on. Does anyone know more or less what I can do to fix that?
Is it completely charged? Plug it in and charge it overnight.
If it is charged, these steps may help:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 16, 2010 | Apple iPhone 3G
IPhone will not turn on i have tried charging via USB on a MacBook but no luck and have tried charging via AC adapter still no luck
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Take care
Mar 25, 2010 | Apple iPhone Smartphone
Battery issue still cannot be solved, hard reboot tried.
Have you tried all the resets:(if you have, bring back to the Apple store)
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jul 29, 2009 | Apple iPhone Smartphone
I cant turn on my iphone, dark screen and stuck on the itunes sig
try to hold the home and power button and try 2 reboot it then wen u see the apple come on let both of them go
Feb 28, 2009 | Apple iPhone Smartphone
Cect p168C will not power on
  1. Turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  2. If that doesn't work, connect it to the iPhone charger and let it charge for at least 10 minutes. Note: iPhone 3G does not support FireWire and will not charge from any FireWire-based power source.
  3. If that doesn't work, toggle the ringer switch to see if the unit vibrates. If it does, it could be that iPhone is getting power, but is not displaying any image. (see "Display has no backlight or dark screen" below for further troubleshooting.)
  4. While connected to the iPhone charger, try to reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
Oct 16, 2008 | Apple iPhone Smartphone
Power buton
Hold the power button for about 2-3 seconds and the release it. If the battery is charged, it should come on.
Aug 30, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
