Question about Homedics Automatic Arm Blood Pressure Monitor ()
How do i clear the readings? - Homedics Automatic Arm Blood Pressure Monitor ()
    Brigadier General:
  • 4,736 Answers
Press the User Select Button to select User 1 or 2. Then press and hold the - & + buttons at the same time, while the memory recall mode and the data for the selected user will be erased automatically.
Hope that helped answer your question.
Posted on Mar 22, 2011
Ti 30x IIS displays memory cleared and will not do
Not sure but try
  • Press the "ON/AC" button to turn the TI-30Xa on. If the top-left corner of the display reads either "M1," "M2" or "M3," a number is stored in the corresponding memory.
  • 2 Press "0," "STO" and "1" if the number in the corner reads "M1." The upper-left corner should no longer say "M1."
  • 3 Press "0," "STO" and "2" to clear the "M2" memory. Pressing "0," "STO" and "3" clears the number stored in "M3" memory.
  • Read more : http://www.ehow.com/how_8623666_clear-memory-ti30xa.html
    Oct 14, 2014 | Office Equipment & Supplies
    Am so sorry i made a mistake. I should have said "How can I clear "read only" on my documents? THe box that should be unticked is already clear.
    The folder or drive may also be marked as read only. The files then will also be read-only.
    Check the folder or drive on the properties tab.
    Oct 11, 2014 | Computers & Internet
    Hello, my 1998 TDM 850 oil level window is ready black since I changed the oil! Prior to that it was reading clearly until after a 100 mile run the next morning it gave no reading/ it read empty! i changed...
    It sounds like you just need to flush your engine and clear out the sight gage.Get some good motor flush and a can of Marvel Mystery Oil. Go ahead and pour in the motor flush and Marvel.Run the bike at idle and about 2500 rpm back and forth for about 5 mins or so constant.Then drain it all out and replace with clean oil and filter.That should clear out whatever gunk you have in the engine.
    Aug 17, 2011 | Yamaha TDM 850 Motorcycles
    I am getting a flashin L and can't make copies?
    L1 = Scanner (reading) feed trouble Scanner (reading)
    L3 = Scanner (reading) return trouble Scanner (reading)
    Reset method :
    * Entering the simulation mode
    1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
    (The machine is ready for entry of the main code of simulation.)
    2) Main code input by 10-key ? Start key ON
    3) Sub code input by 10-key ? Start key ON
    The machine enters the selected simulation mode.
    Press the start key to start the operation of the selected simulation.
    Main Code =(14 Used to cancel the self diag other than U2 trouble.)
    Sub code = 0
    * Canceling the simulation and returning to the normal mode
    1) Press the clear key.
    Copy SIM 14
    Sep 07, 2010 | Sharp AL 800 Copier
    Clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
    clairon model number pu-2294b message on radio reads error 4 how do i clear this to reset thanks
    Apr 23, 2010 | Clarion Car Audio & Video
    Would you please tell me how to clear the memory on my Brother Fax 837MCS? Thank you
    This procedure works on most Brother machines:
    1. RAM clear (most models)
    2. Quickly press function * 2 8 6 4
    3. Display should read maintenance
    4. Press 0 1 for a full ram clear, or 9 1 to retain user data
    5. Display should read reinit for a few moments then redisplay maintenance
    6. Press 9 9 to exit the maintenance mode
    Nov 19, 2009 | Brother Office Equipment & Supplies
    Clear memory from Lifesource digital blood pressure machine
    To Clear the momory you need to remove the batteries and wiat a few minutes. Once you replace the batteries, when pressinr the M for memory, you should see "n 01" and no readings. The memory is cleared. If you see any other number or any readings you did not wait long enough. Try it again and wait a little longer before reinstalling the batteries. If it still did not clear then you have a problem with the unit and you should contact the manufacturer at (888) 726-9966 - 6AM to 4PM PST Monday - Friday.
    Sep 15, 2009 | Health & Beauty
    T8008 printer with message says "replace fuser"
    The 'Replace Fuser' message on the 8008 can be cleared in the following way;
    • Power the printer Off
    • Hold down FORM FEED and ENTER and power the printer on
    Keep the FORM FEED and ENTER keys held down until the printer displays SERVICE MENU - INFORMATION
    • Press the RIGHT ARROW to MAINTENANCE, and press ENTER
    • The Display should read MAINTENANCE - CLEAR FUSER, if it does not press the right arrow until it does and then press MENU/ENTER
    • The Display Should now Read CLEAR FUSER NOT EXECUTE, Press the right arrow until the display reads CLEAR FUSER EXECUTE
    • Press ENTER, and after a pause the display should read COMPLETED CLEAR FUSER
    • Power the printer off and after about 10-15 seconds power the printer back on again.
    The message should now be cleared
    Jan 12, 2009 | TallyGenicom 8008 Laser Printer
    Homedics Automatic Arm Blood Pressure Monitor () Logo
    94 people viewed this question
    Top Homedics Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
