Question about Presto HeatDish Compact Heater
The heat setting control failed - keeping the heat to stay on high - even in the off position. Contection bands do not connect properly. I need to replace just that part that controls the heat settings.for the Presto HeatDish - "Parabolic Electric Heater" Thank you, Thomas Rigney
  • Presto Master
  • 43,501 Answers
Unfortunately these units have a history of welding the contacts together...the thermostat is too light for the current draw...
As far as getting anew one... the thermostats are Chinese made and are not available.
Depending on where you purchased the unit you may be able to get it replaced by them, Costco has been know to replace these units...
As far as Presto goes they see thse heaters as a disposable item...sad...
If you would like to discuss this further, feel free to comment back...
heatman101
Posted on Mar 22, 2011
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
Feb 23, 2015 | Nissan Cars & Trucks
My Nissan Almera 2005 Model keeps blowing heat even when the switch is off. now when l turn on the aircon hot air is mixing with cold air. Could it be the blower resister?
Could be the diverter paddle control that moves to allow cold air or hot air into the duct. It may be staying in the heat position even when you set the control to cool.
Jan 02, 2015 | Nissan Cars & Trucks
Can't fined the proper setting for the freezer dial?
Almost all freezer controls are manufactured to control temperature to the proper temperature control if you rotate CCW , notice the position and then rotate CW, notice the position and then go the the mid position. If temperature is not maintaining the required temperature, you may need a new temperature control thermostat installed. Before you replace the thermostat, check to make sure you have not overloaded the freezer compartment and, If you have an external condensing coil, that it is lint/dust free. Often times people seldom clean the external condensing unit and causes the loss of freezer temperature control. It is important to keep the condensing coil clean because that is where the heat is rejected to the surrounding air. Hope this helps.
Sep 25, 2014 | Cars & Trucks
What is making my 2005 Silverado's blower motor stay on high even when the truck is turned off? It keeps running, it drained my battery.
Your BCM (body control module), must have gone bonkers. Have it checked out. Might just need a little tweaking-like re-setting.
Good luck.
Dec 05, 2011 | 2005 Chevrolet Silverado
Why won't the blade stay on the wheels of my
You need to adjust the tracking, at the very least. Get a user's manual and it will describe the procedure to adjust the wheels to keep the blade tracking properly. If it's a used saw, it's possible the previous owner didn't maintain it properly and you'll have to replace the rubber, or even a wheel (possible but very unlikely).
Jul 13, 2011 | Saws
Replaced Heater Core. Replaced Thermostat, Removed Valve from heater Hose. still no heat.
When re-filling the radiator you need to keep the heater on high heat. If that has no effect, feel both heater hoses to make sure they are hot. Last, I hope you checked the blend doors for proper operation before you put it back together, often they will fail and not open or close properly. a bad vacuum motor that controls those doors can also be faulty.
Oct 28, 2009 | 1986 Jeep Cherokee
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Rock Band calls for the mic when I only want the guitar...
A try this not sure but u can try make sure your stick remote is unpluged then try if not try to control with stick controler to see if u can cut mic off.
Dec 27, 2008 | MTV Games Rock Band for PlayStation 2
ERD36 Oven over heats
If the oven stays off when turned off then it is definitely a controller board problem. - that would mean the element is coming on and there is no control - changed the controller
Regards
Sep 11, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Presto HeatDish Compact Heater Logo
66 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
