Question about GE Monogram ZV1050SFSS 42" Island Chimney Hood
Power to unit, power to pcb, 12ac @ CN4B - neither lights nor fans will turn on.....
  • GE Master
  • 5,370 Answers
If the power and pcb both checked ok then the fan switch, fan motor wirings and light switch are to be checked.If there is a short or cut in the wirings then it will not let the fan and light to work as required.Get the fan switch and motor and light switch checked.-------- Also get the fuse checked and transformer checked.If any of the part is shorted or not receiving power, then its the cause of problem.Because there is power and pcb checked okj so all parts should receive power, if the power is not there on transformer or blower assembly or light switch then its the issue and that part has to be replaced.-------------- For which part is located where and basic parts disassembly.Click this link below.You can also order the parts if required:--------- http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZV1050SF2SS/0432/0122400/G0903304/00001?blt=06&prst=&shdMod= --------------- This should help.Thanks.Helpmech.
Posted on Mar 22, 2011
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
No lights on AC unit but fan is running.
Possible that the processor has failed and it seems to give a through circuit to the fan which runs when power is switched on.
You can check the voltage on the processor IC and if absent then you must check the DC voltage on the circuit board. If there is no power then it is the failure of the power supply section and if not the processor is the suspect.
Sep 27, 2013 | Fedders Heating & Cooling
Carrier 2000ss will not turn on. Checked fuses and they are okay.
Inside the outside unit is a pcb with fault diagnosis lights on. It could be anything from a weak start capacitor to a compressor fault or even short of gas. See what lights are on and check the manual
Apr 21, 2012 | Carrier Heating & Cooling
Power to switch and turned on but no response from unit e.g. no fan or pump engaged. SMALLAIRE conditioner.
Check power in PCB. If yes, PCB is faulty. If you operate with remote and no response, try with another remote and conclude.
Jan 16, 2011 | Heating & Cooling
The power to the fan was turned off at the breaker box, i turned the power back on and now the light or fan won't turn on. i checked both remotes batteries and they are fine. any suggections
I would check all your switches first to make sure you're getting power to your light/fan. If they're all on, then remove the bottom part of the fan where you would splice the wires - and see if you're getting power. If so, then you could have a bad switch at the fixture. I'd try this first before going any further. Feel free to contact me back if this doesn't work. Best of luck to you! Jim
Apr 28, 2010 | Hampton Bay 52 In.Carriage House II in...
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Tv powers on then ''clicks'' off
After the lights on the front of the tv settle down, push and hold the menu and input (or deivice) buttons for 5 seconds. Now count the number of times the LED blinks and follow these instructions.
Cause #1 1. Self-diagnosis error 4-4, check for proper seating of the DVI cable between the FMT PCB and the DMD (Light Engine). It may be necessary to disconnect and reconnect this cable to insure proper connection. 2. Self-diagnosis error 4-4, check for 3.3 volts DC at connector J-9 pin 8 on the Engine Driver PCB, if missing check F9A06 part # 283P128050 on the Power PCB if this is open suspect the 3.3v regulator circuit on the Power PCB part # 930B921002 3. Self-diagnosis error 4-4, check for 3.3 volts DC at connector J-9 pin 8 on the Engine Driver PCB, if missing check F9A07 part # 283P128050 on the Power PCB, if open suspect it to have been opened by the Light Engine part # 939P977020 4. Self-diagnosis error 4-4, if the 3.3 volt supply at J-9 pin 8 is good and the connection on the DVI cable between the FMT PCB and DMD are secure, suspect the Light Engine part # 939P977020 5. Self-diagnosis error 4-1, suspect the Power PCB part # 930B921002
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fujitsu outdoor unit not working
Its possible there has been a power spike and it has dammaged the power pcb. Remove the cover and inpect the PCB's for blackening. If any blakening replace the damaged PCB.
Sep 02, 2008 | Fujitsu 36CS Air Conditioner
GE Monogram ZV1050SFSS 42" Island Chimney Hood Logo
147 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
