Question about Cycling
I want to ship the bike but don't know how to take it apart. I have a bike box. How do I remove the pedals and handlebars? What is the minimum dis-assembly I can get away with? Exactly what tools do I need to do this easily? Thank you for your help!
    Brigadier General:
  • 8,546 Answers
Google: "packing a bicycle for shipping". Many videos.
http://www.google.com/#sclient=psy&hl=en&q=packing+a+bicycle+for+shipping&aq=2&aqi=g5&aql=&oq=packing+a+bicycle&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=73fc2eee6b126d9
I'd advise you to have an experienced cyclist or bike shop supervise and evaluate the process (unless you realy don't care about your bike working upon arrival). It's a rite of passage for any cyclist who travels.
Posted on Mar 22, 2011
A squeak in my bike
Tyler lubricate bicycles chain, pedal bearings and pedal crank.
Check the attached links to see how some cranks come apart to lube,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bottom Bracket Inspect clean and lube
How To Overhaul Bike Bottom Bracket With One Piece Crank
How to Take Apart and Service the Bottom Bracket on Bicycle
Sealed cartridge Bottom Bracket crankset and pedal removal installation...
May 02, 2016 | Norco Cycling
Need pedals for resistant exercise bike with movable handlebars
ive found that bike stores (even online ones) have pedals for decathalon bikes that have the foot straps these should ***** right on to your stationary bike just the same , I will say there a bit pricey !!!
Apr 13, 2016 | Exercise & Fitness
Handlebar grip needs to be replaced
Any bike shop should have those. You may have to split the bad one with a razor knife to get it off. You may want to use soapy water to make putting the new one on easier.
Mar 09, 2014 | Mongoose Maneuver Mountain Bike
My steering his still and cranky I think my bearings have gone not sure how yo undo the head case
Mark:
I don't know what type of bicycle you have, or how modern it is, but the handlebar and steering head are similar on most models. Try to remove the handlebars and steering head from the bike as a unit. There is a large nut at the top of the head tube (where the steering stem goes into). Loosen this nut, and the handlebars and steering stem should pull up and out of the bearing inner races. When you completely remove that nut, the headset will come apart... (including the fork and front tire which will drop out of the headset. If your brake and shifting cables are too short to let you pull the steering stem completely out of the steering head, you'll need to remove the handlebars from the steering stem. If you are careful, the bearing set, spacers and washer will stay on the fork tube when it comes out of the bicycle frame head, so you will know which order to reassemble them in. Either tag them or lay them in the proper order. Now you can clean the bearings or replace them.
It would be a good idea to clean the bearing races at the top and bottom of the steering head too.
Once everything is cleaned and ready to reassemble, grease the bearings and the bearing races and reassemble. When you tighten the stem nut down, make sure that there is no play between the steering head and the steering stem.
Feb 09, 2014 | Cycling
What is a mini exercise bike?
A miniexercise bike is a bike with pedals and resistance parts only. It has no handlebarsor seat. You can use it while you sit on a regular chair and you can move thepedals with your hands for arm exercise.
Jul 30, 2012 | Exercise & Fitness
Bike to high
If the big is really too big, then it's not safe to ride, and blocks on the pedals are not a good idea. On the other hand, if you can straddle the frame of the bike with your feet nearly flat on the ground, then the bike is not too big. You can lower the seat, and many seats can also be adjusted forward and back an inch or two. The optimum seat height is when you put one pedal all of the way down, with the heel of your foot on the pedal, then you should be able to lift your weight off of the seat. You can also bring the handlebars closer if the handlebar stem you have has a typical length offset (if you picture the handle bar stem as an inverted hockey stick, the the offset is the length of the hockey stick blade) - if so, you can replace it with a stem with a smaller offset. If the stem already has a very small offset, you can turn it backwards, but don't do this if the offset is more than 1 inch.
Good luck.
Jun 20, 2012 | Schwinn Cycling
Where can I find a manual for a Healthware Exerglide fitness machine?
hi laurie, your question was put in the sewing machine section, you might
want to put it in another section, like bikes or exercise equipement,that you could have a better chance of getting a answer.
Apr 27, 2012 | Sewing Machines
I dont know how to put my water bottel on my magna bike
Many bikes are sold without a water-bottle holder, but have a place to install one. You will likely have to purchase a water bottle holder, and install the water bottle holder yourself.
Most bikes have a spot for one on the Down Tube. (The Down Tube is the part of the frame that runs from the handlebars to the pedals.) Look on the top of the Down Tube, and see if there are two screws. Likely you will need an allen wrench to remove them and install the holder.
Feb 25, 2011 | Schwinn Cycling
How to get acsess to my handlebars to tighten
You must remove the Nachele to get to the handlebar risers. They are bolted through the top triple tree. Of course, you must also remove anything that prevents you from gettng the nachelle off such as windshield, fairing, and headlight. Note: Sometimes if you turn the front end fully to one side, you and get to the large nut or bolt from the bottom side without removing he nachelle. Turn the front end to the other direction to get to the other nut or bolt.
Now, keep one thing in mind, the handlebar risers are mounted in rubber bushings. This is done to reduce handlebar vibration. Harley has used this vibration dampening system for years on their big twin bikes. Your handlebars may not be "loose" but move due to the rubber mounting. Before I went to tearing my bike apart, I'd feel of some other bikes handlebars first and compare it to what yours feel like.
You can get more firm bushings for the handlebars. Matter of fact, you can get steel bushings that eliminate the rubber mounting.
Go to this site and check out page 990
http://www.vtwinmfg.com/Catalog1/VTwinCatalogIndex1.htm It is the V-Twin manufacturing catalog and shows the handlebar riser bushings. Good Luck
Jan 31, 2010 | 2005 Harley Davidson FLHT - FLHTI Electra...
Cycling Logo
94 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
