Question about Cycling
I have a TREK mountain bike with a Shimano combination brake and shifter with an Altus derailleur. It shifts all gears fine but when coasting with my feet on the pedals, the chain goes slack and sags several inches. Bike was damaged in a flood. I made repairs and had to remove wheels and replace inner tube, clean it up and lubricate chain. I did not remove the derailleur but something is obviously wrong. Is it possilbe that I got the chain wrap on the rear sprocket backward or what? I am stumped. Thanks
    Brigadier General:
  • 8,546 Answers
Only YOU can evaluate any error you may have made. LOOK at why the chain is slack. Does the rear derailleur pull back to take up the slack? Are you using some ridiculous small chainring, small rear cog combination that allows too much chain to go slack?
Perhaps the freewheel isn't freewheeling and is instead feeding chain forward when you stop pedaling. Walk the bike forward and see if the rear cogs just coast. If not, lube time (internal). take it to a Bike Shop or buy all the special tools and DIY.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Posted on Mar 22, 2011
How do I switch gears have a nishiki manitoba 500 series has two shiffters on each side?
the shifter pod on the right is for the rear derailleur and the shifter pod on the left is for the front derailleur. There are usually two shift levers on each pod. Some you actuate with just your thumb, others you use your thumb and forefinger. Generally the larger of the two levers is to move the chain onto a larger size gear cog, one click of the lever equals one gear. Use the smaller of the two levers to return the derailleur, one click equals one gear. This is assuming the cables are adjusted properly, if the cables are not adjusted properly then you won't get a nice "one click = one gear" shift response and you should take your bike to your LBS (local bike shop) for a tune up, or watch some YouTube videos on how to do it and practice.
Jun 11, 2016 | Shimano Xtr Mountain Bike Dual Control...
I just bought a TREK bike with SHIMANO shifter/brake combination. The bike may be 10-15 years old (not certain). The shifters move but do not engage the cable. What should I do?
With a bike this old the best thing is too take the bike into your local bike shop and have them give it a once over to look for any potential problems. THIS IS A FREE SERVICE ALL SHOPS OFFER.
The problem specific could be as simple as the cable is very loose and not engaging the cable, or the cable could be so old that it is frozen inside the housing and nothing is happening. It could also be that the cable is broken, the shifter is broken or something other. It is impossible to diagnosis this particular problem with certainty without actually seeing and feeling the issue.
Bottom Line: Take it into a shop and get a mechanic to look at it.
Dec 12, 2010 | Shimano Xtr Mountain Bike Dual Control...
I bought a mountain bike with Shimano Altus gears over the net with most of the assembly in place. Have indexed the rear gears which work fine. Did the same for the front deraileur works changing up but...
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Sep 12, 2010 | Mountain Shimano Altus Front Bike...
Deraileur adjustment/tuning
Yeah you will run into that at some bike shops. When they see older components like that, they often refuse to adjust them for fear of breakage and liability. Try a different bike shop if you can, or if you are confident in your mechanical abilities, try it yourself, instructions here:
http://www.ehow.com/how_6086607_adjust-shimano-rear-derailleur.html
Good luck.
Mar 27, 2010 | Shimano Xtr Mountain Bike Dual Control...
The shifter moves 9 clicks, but the travel is only enough for 7 sprocket clicks
Shift into the highest gear and then release the shifter cable at the derailleur (it is clamped with an allen [hex] bolt). Pull the cable as tight as you can and re-clamp the cable. You should be all set now. The cable stretches over time and needs to be adjusted.
Dec 13, 2009 | Shimano Xtr Mountain Bike Dual Control...
The front derailer will not stay in gear. It
check the shifter handles also check your cables and cable covers check anchor bolts frame clips anything that can cause your cables to come out of adjustment shimano is quality stuff so start at the shifters and work back to the derailleur .hope this helps
Nov 23, 2009 | Shimano Deore LX Mountain Bike Front...
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
Shimano Tourney rear derailleur is stuck on smallest gear and will not shift. How do I adjust the tension correctly?
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Aug 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Shimano Altus gears
The old lubricant has gummed up. It needs a good cleaning and relubrication.
"STI shifters gum up after years of use. I've had good luck with this method and since it's nearly free it's probably worth a shot--
"Get a can of WD-40 or a similar light solvent/oil solution. Pull the brake lever back to the bar to partially expose the shifting mechanism and generously hose down the interior with your solvent. I mean really get it in there from all directions, using the little red spray tube if possible. Let it sit for a while and then drizzle in some light oil like Tri-Flo or similar. Then wipe down the exterior of the shifter with some Simple Green or other degreaser (to keep the overspray off your hands).
"I've rescued two sets of STI-type shifters with this method. Hope you get your problem solved one way or another, because new Dura-Ace sure ain't cheap."
source: http://www.bikeforums.net/archive/index.php/t-83743.html
Jun 25, 2009 | Mountain Shimano Altus Front Bike...
Cycling Logo
129 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
