Question about Whirlpool Washing Machines
On my whirlpool 7 sense washing machine door light comes on 10 seconds after start and machine stops and wont start without power down
    Brigadier General:
  • 6,277 Answers
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest. Sorry ;-0(
Good luck,
John C
Posted on Mar 22, 2011
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Whirlpool quiet partner III
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
high temp wash
heated dry
high temp wash
heated dry
all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
I Hope this works for you.
Dec 18, 2013 | Whirlpool Dishwashers
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Wont do anything
Maybe door latch adjustment. hold door in at latch and see if it will work
Jan 04, 2008 | Whirlpool AWM8123 Front Load Washer
Washing machine prob
You need to replace the door interlock. Try giving the handle a firm push and see if the machine will start.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
54 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
