Question about Echo Garden
I cant find the serial number on my Echo PB-260 Blower
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 708 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
Posted on May 26, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
spencerfield
  • 31 Answers
SOURCE: my echo pb-2100 gas blower
no spark sounds like the coil, but check the connections and any corrossion in the wires
Posted on Oct 13, 2010
Looking for a serial number for a back pack echo pb-413h blower
if unlucky lost its serial number sticker from petrol spill/heat
if lucky something stamped into the alloy housing of assembly
most mower repair shops can track down sample parts without the serial number
a factory limit of hours on blowers are as little as 100 hours
unless it came with the user book from new purchase
you may never know
Jan 13, 2017 | Echo Garden
About Echo blower Flywheels
Potentially. Give it a try and see if it runs
Mar 29, 2016 | Echo Pb-251 Leaf Blowers
Echo pb-1000 blower
depends on the serial number as they have multiple breaks throughout production of that model... but you have a inlet line a return line and a vent line
Aug 21, 2014 | Garden
Where do you find the serial number of a echo PB403T
Model and serial number are underneath the recoil starter, on the engine block. Tip the blow on it's non-engine side and look right above the tank from underneath the blower.
Nov 04, 2013 | Echo Pb-403T Leaf Blowers
Only runs upside down. When right side up it acts like it runs out of gas
Sounds like fuel line problem. Empty fuel tank,remove black fuel line grommet,check for line break or disconnection.If line is broken , purchase fuel line kit with grommet as a set if lines or grommet are deteriorated.
Aug 29, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Can't find serial # on Echo PB-500T Blower
The number is on the side of the recoil starter, its on a white or silver tag mounted on the underside.
Hope this helps, Matt
Dec 10, 2010 | Echo Garden
Oil/gas ratio for mod. PB 260L
I didn’t see a manual for your blower but page 14 for a PAS 260 says:
“IMPORTANT
Echo Premium 2-Stroke Oil may be mixed at 50:1 ratio for application
in all Echo engines sold in the past regardless of ratio
specified in those manuals”
http://www.echo-usa.com/documentation.asp?Model=PAS-260&lang=E
HTH
Lou
Nov 01, 2009 | Garden
Open Questions:
Garden Logo
122 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
