Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak esp 5 printer ,error code 5202 ,printer will turn on ,scanner bar does not move ,error code 5202 appears on screen,no printer functions will open ,printer will not turn off ,have to pull power plug out
    Novelist:
  • 137 Answers
Try Running Their Repair Utility:
    1. Select .
    2. Click EASYSHARE Software>.
    3. Click .
    4. Click .
    5. Select , then follow the instructions.
  1. Try the feature again.
If this does not help you, and you are still within the one year Warranty period, contact Kodak to arrange a warranty repair or replacement.
http://support.en.kodak.com/app/answers/detail/a_id/7467/kw/warranty%205100/selected/true
Thank You For Choosing FixYa~!
Posted on Mar 22, 2011
Kodak 3.2 ESP has an error clear all paper code 3528 but there is nothing there
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Feb 04, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Tip
Canon Service Error 5202
Service Error 5202 solution for ip1800 / ip1900<br /> <br /> Steps: <br /> 1. turn-on printer, still blinking and a error message on screen, open cover. <br /> 2. While printer cover is open, unplug the power cord at the back. Of course it <br /> turns off. <br /> 3. Remove all cartridges, clean the contact points and then insert them back <br /> properly. Move the entire cartridge to its parking area. <br /> 4. Close the printer's cover, plug the power source, turn the printer on. <br /> <br /> 5. It should be working fine now. Mabuhay!!!
on Mar 24, 2011 | Office Equipment & Supplies
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
Jul 10, 2010 | Kodak ESP 5 Printer
Errors on my Kodak ESP 3250
error 3501: STATUS_ERROR_UNIT_OPENED_WHEN_IDLE. You probably had it open when you inserted your cartridges.
Error 3502: STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY. You must have inserted some shortly after you turned the printer on for the first time so don't worry.
Error 3609: STATUS_ERROR_UNIT_OPEN_WHILE_PRINTING. This is also another basic function on the printer.
I would recommend not looking at the errors on a printer test page as they show all errors that come up on the printer, even if they are not important.
Apr 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner motor move failed error code 6202
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
Kodak esp 5 won't scan
call kodak @ 1800 421 6699. This step involves advanced troubleshooting and is related with the scanner drivers of the Printers. Kodak telephone support will take care of the issue.
Sep 20, 2009 | Kodak ESP 5 Printer
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EASYSHARE 5100 All-In-One Printer Logo
166 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
