Question about General Electric GE 24-Hour Timer, 2-Pin #15004
I have a ge timer 15132 and it is wired up properly feed to screw 1 and 2 , jumper from hot to com, load to no contact and the neutral tied with the other from the feed, all the time are set proper and the switch is set to with the A on the screen coming up it is 120v. Does anyone have any idea why the only thing i can think of is the relay isnt working proper please help.
I have tested this timer.
GE 15132 timer can be wired muliple ways to accommodate different voltages and many different timing needs.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
1) First thing is you must set dip switches BEFORE applying power.
Timer arrives pre-set for 277Volts.
For 120V, set all 4 dip switches to the left, or ON.
2) Otherwise your wiring sounds correct.
Hot black wire to far left 'clock' terminal.
Neutral white wire to next 'clock' terminal.
Jumper from Hot terminal to COM terminal.
Black Load wire on NO terminal.
White Load wire to same 'clock' terminal as Neutral
3) Possible solution:
Move wires to COM2 and NO2 and see if that relay is working.
4) Make sure your programming does not have conflicts.
See if manual override is working.
Test for voltage across 'clock' terminals
Move manual override and watch if relay clicks open-closed.
Check that Load is operable by moving NO wire to COM terminal.
5) If timer is not functioning, exchange at Home Depot.
You can switch out mechanism without replacing box.
Mechanism is held with hex screws.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 22, 2011
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2014 | Hardware & Accessories
How to wire a ge 15350 timer for two 120 circuits
1) Copy following links for GE 15350 timer single-pole single-throw 120Volt timer (Made by Tork, same as Tork 1101):
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
2) Use following link to control one 120volt load
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
2) To control two 120Volt loads:
Use wiring illustration above.
2nd 120V load will have black and white wire, same as 1st 120V load..
Connect 2nd black wire to terminal 2.
Both wires must be same gauge and solid wire. Do not use stranded wire under screw-down plates.
Connect 2nd white wire to terminal X.
Except do not connect more than 2 wires to screw-down terminals. Instead join white wires with wire nut, and then add jumper that connects between wire nut and screw-down terminal.
Jan 17, 2013 | Hardware & Accessories
I have TORK 1104 , I need control 2- louds (same face) I understood L- hot 1 from breaker, 1- hot 2 from breaker, X- com to loud 1, 2- is com to loud 2. BUD WHERE MUST BE CONNECTED NEUTRAL???
Tork 1104 is 240Volt timer.
Same timer is repackaged and sold as GE 15307
See wiring diagram for single load 240Volt:
http://waterheatertimer.org/images/GE-15307-wiring-250.jpg
On the 1104, there is not a separate terminal for Neutral wire.
240Volt circuit does not require neutral wire to complete circuit, so 240Volt timer does not have terminal for neutral.
If you want to control two 240volt loads, then this is not the best timer.
I recommend GE 15207 from Home Depot or Heavy-duty Intermatic GM40 available on-line.
If you want to control two 120Volt loads using Tork 1104, then connect 240Volt lines to to terminals L and 1 as shown in diagram above.
Bring your neutral wire into the box, but do not connect neutral to any terminal.
Each 120Volt load has black and white wires. The whites are for neutral so tie them into the neutral wire using wire nut. Connect black wires to terminals X and 2. If you want both 120Volt loads on same phase, then connect both black wires to terminal X.
Resources:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Sep 25, 2011 | TORK Variable Cycling Timer 8601
How to wire a intermatic timer T104 240 v to a 120v?
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Dec 26, 2010 | Intermatic T104 24h 208-277v Mechanical...
Why do I need to use the Jumper? Does the timer close the circut on the nutrel side only or does is close both ?
EH10 has four screw terminals: 1 2 3 4
EH10 has two screw terminals exclusively for electronic clock motor.
These terminals connect exclusively to clock ... there is no internal jumper that passes power to another terminal.
Terminals 2 and 3) Black Hot lead connects to two terminals. Hot connects to terminal 2 and to terminal 3 ... so you put a jumper wire between terminals 2 and 3.
Terminal 1) All neutral or white wires connect to terminal 1, so there are two white wires on terminal 1.
Terminal 4
) Black wire going to 120V Load connects to terminal 4.
Contrast EH10-electronic-timer with T-101-electro-mechanical-timer. T-104 clock motor has two separate wires that connect to terminals A and 1. Electronic clock doesn't have those separate wires.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Your second question about closing the circuit.
When timer turns ON, it closes circuit between terminals 3 and 4.
So the Hot is closed.
Neutral is not closed, it is open at all times.
EH10 is SPST timer ... One single pole is opened-and-closed (SP), and timer completes action with a single throw (ST)
Nov 24, 2010 | Intermatic 7 Day Electronic Timer Eh10...
How to wire a 1104 series time switch
8896f6e.jpgTork 1100 series
Tork 1103 can control 120V or 240V Loads (fan light motor)
It can control 1 or 2 different Loads
Tork 1103 has 5 screw terminals
L 1 Unmarked X 2
The Tork 1103 has a 120V clock motor that consumes 3 Watts and costs $3.50 per year to operate.
1) You have to have a white Neutral wire from breaker box connected to Unmarked terminal no matter if you are controlling 120V or 240V Load
2) You have to have a black Hot wire from breaker connected to terminal L no matter what load
If you have 1 Load 120V:
Terminal L black hot from breaker
Terminal 1 no wire
Unmarked terminal white neutral from breaker
Terminal X black wire going to Load
Terminal 2 no wire
White wire going to Load connects to Unmarked terminal
So 2 white wires are on terminal 2
If you have 2 Loads 120V (Load1 Load2)
Terminal 1 jumper your black hot from Terminal 1
Terminal X black wire going to Load1
White wire going to Load1 connects to Unmarked terminal
Terminal 2 black wire going to Load2
White wire from Load2 connects to Unmarked terminal
So 3 white wires are on terminal 2
If you have 2 Loads 240V
Unmarked terminal white neutral from breaker (no other wires connect to this terminal)
White wire going to Load1 connects back to 240V breaker
White wire from Load2 connects back to 240V breaker
If you have more questions, add a comment and I will help
Oct 30, 2010 | TORK Variable Cycling Timer 8601
Im r\putting in a new timer, i have 120 going in to the line, terminal 2 , and 2 load circuits hooked up to termials 4 and 6, neutral on terminal 1. When i power it up i have 120 volts on terminals 1 and...
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
I am looking at the wiring diagram
The timer is shipped pre-set for 120V
DST enabled
Loads to be independently controlled
Move jumper to SIM for simultaneous operation
STATIC discharge can damage circuit board
neutral on pole 1
hot on pole 2
Now your 120V circuit powers the timer, but it does NOT send power to the other poles
If I understand your explanation correctly ... you have load wires on poles 4 and 6 but no Hot wire connected to poles 3 and 5?
I think you need to run a Hot wire to poles 3 and 5.
To double check this, run a continuity test between Hot pole 2 and poles 3 and 5 ... there is no voltage there ... the switch circuits operate separately from the timer circuit.
Another test ... when you hear the switch click ... test continuity between poles 3 and 4 and then test poles 4 and 5 >>> when the timer is on, those poles have continuity ... so connect Hots to 3 and 5 and the 2 Loads will work.
Oct 04, 2010 | Intermatic ET8215C- 7-Day Electronic...
Model T104P wiring instructions for 110volt motor
T104 timer is for 240 Volt circuits. It has internal 240V clock motor. Clock terminals and timer terminals are connected, so there is no way this timer can control 110V circuit.
T101 timer is for 110V circuit.
T101 has 110V clock motor
Both white neutral wires = terminal A.
Black hot wire from breaker box = terminal 1
Black wire to load = terminal 2.
Grounds = green screw
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
T103 timer is for 110V circuit
T103 has 110V clock motor
Black hot wire from breaker box = terminal 3
Black hot wire to load = terminal 4
T1905 timer is for 110V circuit.
T1905 has 110V clock motor
Both white neutrals = Clock terminal
Black hot from breaker = COM
Black to load = NO [load comes on when timer turns on]
Sep 21, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Wiring program timer switch model t1905 intermatic
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See timer manual at Intermatic: click on T1905 to see pdf manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial%20with%20skipper.aspx
T1905 has 4 screws: NO normally open > NC normally closed > COM > Clock
NO screw is on left
NC screw is 2nd from left
COM is 2nd from right
Clock is on right
A) How to wire t1905 for 125V
You will have four wires >> a Black and White from breaker box; and a Black and White to load
1) Black hot wire from breaker connects to COM
2) White neutral wire from breaker box connects to Clock
3) White neutral wire to load connects to Clock
4) Black wire to load connects to NO -or- NC screw [one of these screws will have no wire attached]
NO turns 'off' with times set on timer
NC screw turns 'on' with times set on timer
If you want your load to turn 'on' when timer clicks 'on' then connect Black wire to NC screw
B) How to wire t1905 for 240V
You will have four wires >> 2 hot wires from breaker box; and 2 hot wires to load. These wires might be Black and White or Black and Red
2) Red or White hot wire from breaker box connects to Clock
3) Red or White hot wire to load connects to Clock
4) Black hot wire to load connects to NO -or- NC screw [one of these screws will have no wire attached]
If you want your load to turn 'on' when timer clicks 'on' then connect black wire to NC screw
Sep 10, 2010 | Intermatic Timer T1905 24 Hour Dial 120V...
General Electric GE 24-Hour Timer, 2-Pin #15004 Logo
471 people viewed this question
Top General Electric Hardware & Accessories Experts
Marvin
Marvin
Craig Butler
Craig Butler
ray gallant
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
