Question about Motorola Mobility HS850 Consumer Headset
My HS850 headset won't charge. I have tried two different chargers and when you plug the headset in, there is an instant blue light that then goes right out and no charging at all. Any suggestions? I can solder!!
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
designyou
  • 13 Answers
SOURCE: Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Posted on Aug 02, 2007
SOURCE: Plantronics Bluetooth Headset P590
my headset doest charge too. i tried the desktop stand...and the AC adaptor....but no power comming through. i cant say that my power isnt working coz when i tried the universal adaptor...that was charging fine. i have got a P590. PLZ HELP.....thankxxxxxxx
Posted on Jun 17, 2008
  • 46 Answers
SOURCE: HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Posted on Jun 18, 2008
SOURCE: The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
Posted on Sep 16, 2009
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
The pairing light on my HS850 soes not come on?
You have to start with the boom closed and press the large button with the phone symbol until the blue light comes on, then open the boom before the light goes out and you should be able to pair it with your phone.
Feb 26, 2010 | Motorola Mobility HS850 Consumer Headset
My hs850
Press and hold your power button for about 10 seconds, unitl the blue light starts flashing. Most people just push the button and think it will turn on, but you must hold it for a while and it will turn on.
Aug 15, 2008 | Motorola Mobility HS850 Consumer Headset
HS850
make sure the ac adapter isnt bad
Jan 19, 2008 | Motorola Mobility HS850 Consumer Headset
Moto bluetooth HS850 WON't turn ON!
I think your guess is right a new battery may be required but try leaving it on charge for 12hrs or so sometimes if they havn't been used for a long time they go dormant and it takes a realy good charge to get them going
Nov 08, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850
close the boom and hold multifunction button E when the blue light lights up open boom.
Sep 29, 2007 | Motorola Mobility HS850 Consumer Headset
May 09, 2007 | Motorola Mobility HS850 Consumer Headset
Won't turn on, take charge, communicate
I have the same one and let it go dead all the time. It will take 5 - 10 minutes after you plug it in for the blue light to come on when it's dead. Mine recently decided to WOULD NOT charge. It turned out to be the three little pins on the charger were dirty and sticking. I used a cotton swab to clean them with some rubbing alcohol and a quick dab on the contacts of the headset. Works great now.
Nov 18, 2006 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
134 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
