Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Hi. I have a Cabriofix seat.My daughter has just damaged the energy absorbing foam(split it in half).Can i replace this?
  • Maxi-Cosi Master
  • 1,629 Answers
Replacement polystyrenes for the Maxi Cosi CabrioFix can be ordered via your local Maxi Cosi retailer.
Posted on Dec 13, 2011
Get a lot of vibration on the high spin cycle. Looks like I need to replace the bearings. Can you replace just the bearings? I saw the whole drum can be replaced.
It depends on the make and model of the machine you have. Some drums are bolted together with a front and a back half that split apart. some are heat sealed at the point of manufacture and can't be split. If you take the top off your machine, it should be pretty cleat if the 2 halves are bolted together (You will see bolts). Just be aware that for the noviice, this is a nightmare job. Not only do you have to get the drum out, you then have to knock out the old bearings with ppopriatly sized drifts, without damaging the seats they sit in. THEN you have to get the new ones in without doing any damage to the bearings ot the seats, then you have to get the seal between the 2 halves to seal without any leaks. I recondition machines for a living and I avoid bearing swaps like the plague. I would seriously consider consigning the machine to the scrapheap, rather than doing it yourself!
Sep 25, 2015 | Washing Machines
REPLACING FOAM
The polystyrene is what protects your baby from harm in the event of an impact. It is not recommended that the seat is used with damaged polystyrene.
You can obtain a replacement polystyrene via your local retailer or by contacting the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 (Excluding Bank Holidays)
May 29, 2012 | Dorel Maxi-Cosi By Bebe Confort Streety...
I've lost the head rest and back support foam. Where can I buy a new one?
Good Afternoon
The headhugger/lumbar support wedge are not available as a seperate spare part item from Maxi Cosi. They come as part of the complete replacement fabric set for the CabrioFix carseat.
If you're in the UK you can order the complete replacement fabric set via your local Maxi Cosi retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The RRP is £39.99 and if you purchase direct cost will be RRP plus £3.99 p+p.
If you're outside the UK please go to www.maxi-cosi.com and select the country you're in, then use "Contact Us" to enquire about availability and costs from the customer service department in your country.
Jul 25, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
My fabric on my maxi cosi cabriofix seat has discoloured colour black how Mitch will it cost to replace?
Not sure where you based. In the UK there about £20 on ebay uk.
I hope this helps.
Regards,
Liz.
Feb 20, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Ive got a maxi cosi cabrio fix - i washed the headhugger/bottom support cushion that comes out (for when they are tiny) and the material has torn and the foam inner has come out - can i get a replacement...
It is normal for the headhugger to be attached to a peice of fabric lower down that contains the newborn foam cushion, this fabric is usually open so that the foam can be removed for washing.
If you want to purchase a new part, contact the link below, who will be able to assist.
http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en
I hope this helps.
Nov 02, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
My daughter is only 18lb's but seems too tall for the maxi cosi cabriofix. when can she move in to her maxi cosi axiss???
You should keep your child in her Cabrio carseat unless she exceeds 13kg OR her head is higher than the back of the carseat. Make sure that you have removed the newborn support and head hugger too as this can free up a lot of space.
If she is too tall for the Cabrio and is at least 9kg and can sit un-aided for 20 mins, she can move up to the next seat (group 1), this would be the axiss.
I hope this helps.
Oct 24, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Broken handle
If you contact www.maxi-cosi.com they should be able to advise althought I fear that you will have to buy a replacement car seat shell as I am not confident that just the handle can be replaced.
I hope this helps.
Sep 07, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Aug 14, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Spare Parts
Contact Maxi-Cosi on 01842767965 as they sell a replacement fabric set for £40 plus postage which includes the head hugger etc. Not sure about the foam but they will tell you if they do it.
This is also available from some Maxi-Cosi retailers to order and may save the postage. Google maxi cosi replacement fabric and you should get some options. Hope this helps!
Apr 19, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
187 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
