I have a hunter ceiling fan 5 blade 3 light....the glass is bell shaped however doesnt stay on with the 3 set screws instead the glass has a triangle belveled end that slips in and turns being held by inside clips.... i busted one of the glass...home depot where i bought it at says they dont caryy any replacement glass like it ....please help
  • JPR Mar 22, 2011
    that doesnt help you missed the point ....the triangle on the end of glass is how it attaches ....there arent any set screws or holes....
    Brigadier General:
  • 4,736 Answers
Home Depot may not, but Lowe's probably does. In addition, since it's a Hunter Fan, many of the Lighting Stores carry the glass fixtures for ceiling fans. It shouldn't be that hard to find. Just take an unbroken one with you for comparison.
Posted on Mar 22, 2011
  • Rich Landrum Mar 23, 2011
    I agree it's unique. But, what I said before, I still standby. Lowe's also carries Hunter, as do many of the lighting stores. Of course, if all else fails you could order from Hunter or look online. I'd recommend Southern Comforts www.southerncomforts.com
    That should have been www.southernhomecomforts.com
Hunter 20765
I found my own answer by calling Hunter Fan Technical support. They informed me (even though its not in the manual) I have Hunter Blades called "Easy Lock". I had to remove the Hunter arm and blade away from the ceiling body fan in order to figure how to remove the blade. Once I removed the arm which is attached to the blade; I laid it the blade portion on my lap and then the arm away from my body. Then I picked up the small clip unlocking mechanism toward me and then slide the clip unlocking mechanism toward the left of my body. Then the blade came right out. There are no screws to attach the blade. You just reverse the procedure for to lock the blades back into place.
May 16, 2013 | Hunter 20765 Stratford II Fan
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Cant remove the fan from the ceiling and the top ring wont turn
The top skinny ring that is made of plastic is the one that needs to turn. The metal bell shaped piece does not turn. My plastic ring would not turn either. I took a flat blade screwdriver and stuck it between the plastic ring and metal bell shaped piece. I gently pryed the plastic ring away from the bell shaped piece. The plastic ring has 4 screws that hold it in place, they are at the 8 oclock, 10 oclock, 2 and 4 oclock positions. The ring has to be turned counter-clockwise when looking up at the fan from underneath. Once the ring is off take the 4 screws out and the fan will come down.
Nov 15, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Glass replacement for Hunter fan
Hi, hunter fan glass replacement can be found at amazon, take a look here and chose: Amazon com hunter fan glass replacement. Regards. Donald
Jul 10, 2009 | Dryers
Ceiling fan
If the fan blade mounts are removable, go to your local hardware store with one of the mounts, and find some screws that will fit. You might not be able to get the same color, but if you check a few stores you should find something with the right shape of head to fit snugly.
Apr 17, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
