Brother MFC-7220, paper coming out like a Fan. MFC-7220, paper coming out like a Fan. All creased or not coming out at all and jamming at the back. Any ideas.......your fuser has gon bad or something is blocking the paper path. Open i don't think so, because when i hold or put some presure on the back cover the paper will come just fine. do you think there might be a spring missing or weak
  • 492 Answers
You may have a weak spring but also you might try adjusting the roller inside. If it does not take a lot of pressure on the cover you might be able to set something (like a book) on it. I have had some luck just changing the paper and cleaning the insides.
Posted on Mar 22, 2011
Brother MFC-7220, paper coming out like a Fan. All creased or not coming out at all and jamming at the back. Any ideas....
your fuser has gon bad or something is blocking the paper path. Open the back and look close for any objects. If nothing there you need a new fuser. Steven 805-520-3003
Jul 08, 2010 | Brother MFC-7220 All-In-One Laser Printer
MFC-7220 All-In-One Laser Printer: the back cover open message will not go away...
There is a paper jam in the machine which is blocking the sensor for the back cover.
Remoev the drum and toner (cartridge) from printer and look inside, there should be a piece of paper there, you need to remove it slowly
May 16, 2010 | Brother MFC-7220 All-In-One Laser Printer
The paper fold when i print documents from pc? why?
the printer roler settings have changed or the roller has gone faulty ... get the printer serviced
Jan 12, 2010 | Brother MFC-7220 All-In-One Laser Printer
Paper jam and 2 found springs
Those 2 springs should be re-installed, they should be put back in place in the paper guide assembly in the back they should be there to apply pressure to the feed rollers so the paper will feed.
Aug 20, 2009 | Brother MFC-7220 All-In-One Laser Printer
Leaking toner all over paper and you can't read the information that is printing and alot of paper jams.
Remove the cartridge as it is faulty. Clean or vacuum the area under the cartridge (with the machine switched offf please) and fit a new cartridge.
Jul 09, 2009 | Brother MFC-7220 Plain Paper Laser Fax
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Document jam
Check again, this time with a torch and tweezers! It sounds like a very tiny jam so very small it may have been missed. Open up cover and check inside everywhere. Good luck.
Apr 27, 2007 | Brother MFC-7220 All-In-One Laser Printer
85 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
