Question about Health & Beauty
Famosa dareway instruction manual i need this to problem solve thermal fuse as charging light not showing
3 Suggested Answers
  • 3 Answers
SOURCE: light goes out when I
Phone 0844 561 0008
That is Feber's number. I just phoned and they were very helpful. If it is under warranty then they are great. And if you need spare parts they have them all.
If you are using your warranty you will need your Warranty Number which is stamped on a piece of paper, your Manual and your receipt where you bough it.
Posted on Dec 30, 2010
steves_here
  • 1692 Answers
SOURCE: How do I charge my dareway? I have no manual
Hi Kim, Google search "service manual" +brand+model number and you should find a free manual on that web page..... CHEERS
Posted on Apr 01, 2016
My 18 gauge Ryobi nailer, with a fully charged battery, will not fire and the light just flashes?
Read the manual. The flashing lights indicate one of several conditions (out of nails, jammed nail, etc.). The manual has clear, easy to follow instructions for troubleshooting.
Apr 09, 2018 | Ryobi Tools & Hardware - Others
Apr 01, 2016 | Cameras
The screen shows an error H:E what does it mean? I don't have the instruction manual
Just a guess Heating Element If it failed then replace a thermal cutoff $3 or so it acts like a fuse in devices that make heat.
Oct 21, 2013 | White-Westinghouse WWTR442 Breadmaker...
I need new pink stickers for dareway scooter
hi i need hanna montana stickers for dareway scooter
Apr 14, 2012 | Health & Beauty
Hi..! I am trying to find a replacement right hand side cog for my son's black and gold dareway. Can you please help..? Thanks, Mark
I didn't have much luck trying to find parts for you, but there is this:
http://www.darewayuk.co.uk/contact.php
You could try asking for the part there.
I also found this info about Famosa, the main importer of the Dareway:
http://www.hktdc.com/manufacturers-suppliers/FAMOSA/en/1X03W3O3
Good luck, and I hope you find your cog!
Jun 30, 2011 | Toys
Schumacher battery charger sf-1252-ma thermal fuse does anyone know what the number is off of this fuse
The thermal fuse (1 shot fuse) is a #U25 from
Uchihashi Corp. The link below will take you to their page showing the fuse type and ordering information. Probably not found at a local electronics store.
http://www.uchihashi.co.jp/english/image/pdf03ae.pdf
Nov 20, 2010 | Schumacher & Fast Charge Starter Charger
Strandby power indicator flashes 6 times repeatedly
According to the symptom the problem is of thermal fuse which needs replacement, the part number is given below:
1-910-006-44
The method to change it, is given below:
1-Remove rear cover
2-Remove sub-woofer speaker box
3-Remove metal backing plate
4-Remove Exhaust fan
5-Remove Optical block screws
6-Remove Open thermal Fuse
7-Install new Thermal Fuse
8-Reassembly Connection & Wire-dress.
Act according to the instruction and it will solve the problem.
Thanks
Nov 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I need to put in hi-limit thermal fuse how .show
Hello Friend, This problem will be an easy quick fix for you. All you need is a thermal fuse, your cost under $20. Remove back cover from dryer, look down towards where the air blows out, then just to the left where all the wires are. You will see a little white plastic part with two wires plugged into it, this part is called a thermal fuse. Just unplug these wires and replace the thermal fuse. This should solve your problem. Happy to help, Tim.
Jun 23, 2009 | Kenmore Dryers
Sony Wega KDFE55A20 screen and sound going out, red blinking lights, but comes back on...then repeats. Replaced the bulb about 8 months ago and seemed to solve the problem. But it is occuring way too often...
p# 19100239 6 blinks indicates fuse. Do not plug set into switched outlet. besure set is allowed to cool down before ac power is ever removed. Thermal fuse is on the optical block under the lamp housing. do goole search for part availability and source.
Apr 25, 2009 | Sony KDF-E55A20 55 in. LCD Television
Laptop power connection faulty
Hallow Dear,
As your explanation about Battery issue simply I’m advising you to replace your battery with original one.
But before that there is one thing that you can try it out.
---Use your laptop until battery goes down & shutdown automatically then remove the battery and try to discharge it completely with small bulb manually
When it’s on completely discharge (0 Volt) keep it on Outdoor Sunlight about 12 hours.
After that connect it to your laptop & recharge it completely (until Computer LEDs showing you as Fully Charged)
****** REMEMBER DO NOT TURN ON YOUR LAPTOP******
Until its Showing you as fully charged
That will be nice if you can check Battery Voltage & Amperage manually as it is charged fully before turn on your laptop. (if not you can give more charging time accordingly)
This will not solve your any component (thermal fuse, vRegulate) problems inside your battery but will increase your battery Cells Life and most vStoraging problems on Cells inside your battery
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv6000z Notebook
Health & Beauty Logo
345 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
