13387.48:16806 error code on Xerox Workcenter C2424
Having the same error message for Xerox Phaser 8560. Printer is plugged straight into the wall. Any suggestions?
Posted on Mar 25, 2011
  • 41 Answers
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Posted on Mar 22, 2011
4 Suggested Answers
  • 2072 Answers
SOURCE: xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Posted on Mar 28, 2008
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
  • 398 Answers
SOURCE: Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Posted on Jun 25, 2009
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Xerox c2424 error codes
Drum disconnect. The drum heater is not drawing the expected
power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS's) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir
heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48).If you do not hav a UPS connected then probably it is the drum heater problem
Aug 05, 2014 | Xerox C2424 Copier
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
C2424: error code 19,993.48:88868
This error is a Printhead error, but in this case is usually more probable to be caused by the Electronics Module.
The Printhead part number is 650-4354-00
The Electronics Module is 119-6427-03
I suspect the actual error code was 19,003.48
Whit
Item, Inc.
Oct 03, 2010 | Xerox C2424 Copier
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Linux or Mac OS X support for Scanning
You need to download the correct drivers for the OS.
You can go to this link:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=C2424&Xlang=en_US&Xcntry=USA&source=XOG
And download drivers from there according to your OS. Please Select proper OS otherwise you will be downloading Windows by default. On this link there is also utility programs free and so forth; you might find something useful.
Please Rate :) Porfavor
Oct 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcenter c2424 error code 39,014.40;33151
1 1.
2 1.
2.
3.
3 1.
Are the lamps on?
lamp(s).
Mar 28, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
213 people viewed this question
k24674
jasbo
jasbo
