Start up when i boot up my computer its start up then after a few seconds it closes down automatically
    Novelist:
    Scholar:
  • 125 Answers
If the Computer In question is a PC Desktop computer a few issues. First power supply may be malfunctioning. Second check the the CPU fan inside computer is running and not full of dust when you turn it on. If it's dusty, get vacuum cleaner and clean it. Fans need to be able to work without overheating because CPU runs hot.
Thirdly try to take out battery and restart computer. If starts up replace with new battery.
In Case it's a laptop. Take out battery and try to run using power supply and if turns on place battery back in. If battery isn't charging you will need a new battery. Let me know how you go!
Posted on Aug 03, 2008
So I replaced a burned out motherboard with this motherboard. However, it'll crash when windows tries to start. . I've tried Re-formatting the Hard Drive, at the suggestion of a friend that the current...
when you format a hard drive, everything is wiped clean
no operating system , nothing
what you have to do now is to used a cd drive ,internal or external, and put the win vista operation system in it
Now start the computer at the same time holding down the delete button until you get the bios screen up using the arrows move to the boot up section
set the cd as the 1st boot option save yes and press escape button
shut the computer down , wait a few seconds the press start again
If you have saved the boot sequence correctly the cd will start and the win vista program will load and the screen will open
when it is completed and the computer is running and you have finished , close it down wait a few seconds , start band hold the delete key down , go to boot in bios and change the 1st boot to hard drive
for future reference , when you are having problems do not format the hard drive , instead in the search bar under the programs , type in chkdsk and enter and let the computer do the job
it will take around 6 hours to fully check every file folder program, and registry and will repair as it goes
Nov 11, 2017 | Intel D945GPM 945G Ewith Windows XPress...
Our 2009 G6 gxp's passenger window will not seal after the door is closed causing door ajar light to come on and dome lights to remain on
if the window isn't automatically rolling up when u shut the door u can reset the memory by turning till ur dash lights are on only don't start the car , then hit the window up button for few seconds then down button few seconds after the window is down then roll the window up should be fine
Mar 07, 2010 | 2009 Pontiac G6
Reinstall
To reinstall the Operating System? (Examples: Windows XP or Windows Vista) If you have the Full Installation Disk, and the computer plugged into power and turned on, insert it in the CD/DVD drive. Close the CD/DVD drive.
If the disk does not automatically start up, press the CTRL, ALT, and Delete keys AT THE SAME TIME.
This will restart your computer. When the computer manufacturer logo comes up, look VERY closely at the bottom of your monitor screen. You are looking for the key on your keyboard to press, that will let you enter the BIOS Setup. (Older computers its stated as -> Enter CMOS Setup)
It may state -> enter Setup. Or it may state -> Change Setup. Or something similar.
This screen goes by VERY fast. You may have to restart the computer a few times to see it. Write it down.
Once you see the key you need, be ready to start tapping this key in two second intervals, right after you restart the computer again.
When you are in BIOS Setup, look for the Boot Options menu, and enter it. Change the first boot device to CDROM. Be sure to press the F10 key when you have made this change, press the -> Y key, and then press the Enter key.
Your computer will now restart, and boot from the Full Installation Disk you have in the CD/DVD drive.
You can also go to your computer manufacturers website, look for -> Support, and click on it. In the search box on this page, type your computer model name, and model number. On this page look for Contact Us. (HP is Contact HP)
Email them, or call them and tell them you need the Restoration Disk. Some call it the Recovery Disk, or System Recovery Disk.
When you get the disk, put it in your CD/DVD drive tray, close the tray. Let it load. When it aks you, I suggest you click on -> Repair, not Fresh Install.
May 09, 2009 | Computers & Internet
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Windows Explorer error after pressing Start -> Turn Off Computer!
Do you close down your applications first before shutting down? If not, give that a shot. If that fails try closing things down in the System Tray (icons by the clock). Try these things first and if that doesn't work, I have a few more things to try.
Jan 16, 2009 | Microsoft Windows XP Professional for PC
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
WHEN i BOOT UP MY COMPUTER IT STARTS THEN AFTER A FEW SECONDS IT CLOSES DOWN AUTOMATICALLY
This behavior on your PC can only be caused by a malware/worm/trojan/virus. If you can no longer start any applications because it quickly shuts down, the only solution is to re-format and re-install your computer. If you still have a chance to run system restore, then restore it to a point where it is still working properly.
Aug 03, 2008 | Computers & Internet
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
