Question about Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
The indicator panel is flashing drainage blocked. I've checked the drain pipes and there fine. how do we fix this
    Brigadier General:
  • 6,277 Answers
You will need to gain access to the drain motor filter. Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
  • 2 more comments
  • 3319 May 29, 2011
    Aloha,
    Oh my goodness this information was so helpful and you were right about the front circle pannel being a stinker to take off where the drainage pump is located at lower left front footing pannel, but once we removed the front circle pannel it was smooth sailing from than on. I removed all kinds of stuff from the drainage and it is in working condition again. Thank you, Thank you, and Thank you :-)
    From: Katherine (House Manager) at Family Promise of Hawaii in Honolulu
  • Vinny Barber Jun 24, 2011
    Great advice, worked like a charm. Fastest washer repair ever -- washer flashed "drainage blockage" , searched internet found this post, cleaned filter and motor -- 10 min total.
    My advice would after you remove the front plate use a wet vac holding the nozzle near the filter cap. As you slowly open the cap **** up the water. If you do it slowly enough you'll avoid a mess.
  • john_cross Jun 24, 2011
    Good advice about the 'wet' vac. I will add that to my advice but with acknowledgment to you! Cheers, John C ;-0)
  • Carole
    Carole Apr 24, 2014
    We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash drainage blocked. We vacumme out the water and set it to spin cycle. Once most of the water is out it will finish the spin and drain cycle by itself. Next we reset the 'wash' cycle to use as a rinse cycle and then repeat the process to finish the load. Could it be a computer chip in the board gone bad? Sure wish it would be an easy fix and we could get up off of the floor! :)
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
I have godrej gda 902 water is not getting drain after its first cycle of process can any one tell me what might be the problem
The drainage pipe is blocked up. this is a common problem amongst washing machines. People forget to check the pockets before a wash and dirt and fibers start to get stuck inside of the pipes and soon it is blocked and will not drain or drains very slowly.
Solution is to take the machine outside and unhook the drainage pipe. most of the time the blockage is there and is easily removed.
If not, hook the machine up outside and when the drainage cycle is suppose to start try to see if the blockage can be removed by spraying high pressure water up where the pipe has been disconnected. The resulting push of water from both sides may be enough to breakup the materials blocking the pipe.
Apr 24, 2014 | Washing Machines
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Doewoo no frost fridge freezer is working fine except that we keep getting puddles of water under the freezer door. any ideas. had about 4 years now
probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Sep 02, 2012 | Daewoo Refrigerators
Water is dripping from the inside unit and not coming out of the drainage pipe outside
The reason the water is coming out of the unit and not the drainage pipe outside is for a few possible reasons.
1 -the drain pipe is clogged / plugged (due to calcium build up,or frozen)
2- the line is kinked or blocked.
check the drain pipe carefully, there may be obstuctions.
Feb 21, 2011 | Heating & Cooling
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine. Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor. pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards. If the pump is too old or worn out then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
Dirty water that does not drain from the filter housing.
hello,
what this indicate mean that there have been a block on the pipe (house)what you are to do first of all is to bale out he water from the drum then trace the hole down to the pipe remove all forms of dry you can fine around the pipe blockage then problem of non drainage will be solve .
thank you.
Aug 07, 2010 | Bosch Washing Machines
My washed won't drain on spin cycle
hello,
thank you.
Aug 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Hot water won't come out.
hello,
what this indicate is that there is a blockage on the water lay(pipe or drainage ) out for water
what you need to do to fix up this problem from first of all bale out the water from the drum and them trace the pipe that is the way out for water you will see or fine some dry that has block the drainage remove all dirt as the case may be then the problem is solve once you can remove the dirt that has block the drainage .
thank you and thanks for using fixya.
Jun 18, 2010 | Whirlpool WTW5300SQ Top Load Washer
My washer flashes a 02 error during the final spin/drain cycle.
f02 is a fault indicating poor drainage, try removing hte front access panel and cleaning out the pump housing!
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer Logo
125 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
