Question about Magellan GPS
How do you regulate the elevation on the 315. I have set the elevation at my house, but when I move several feet down toward the lake, the GPS does not stabilize. When I stop at any location the elevation keeps changing, and never seems to stop on a certain number.
  • 17,970 Answers
Altitude can be referenced to any of:
1. The WGS84 ellipsoid (a mathematically defined surface which forms the basis for GPS position calculations)
2. A selected datum's ellipsoid (another mathematically defined surface - shifted with respect to the WGS84 ellipsoid, but usually defined to closely match the local surface of the Geoid for a geographic region).
3. A Geoid (a surface of equal gravitational potential - caused by density variations within the earths crust)
4. Mean Sea Level (slightly different from the Geoid surface, because of permanent ocean currents, winds, temperature and salinity differences)
Coordinate data transmitted using the Garmin protocol is transmitted in WGS84. If there is no height information, then the height is assumed to be zero on the WGS84 ellipsoid. If there is height information from the GPS, then this is assumed to be referenced to the ellipsoid of the datum which is currently set in GPSU. If you now display this data using some other datum, the altitude is referenced to that datum and you will see a value which represents the difference in height between the two datums (or ellipsoid surfaces).
Coordinate data tranmitted using the NMEA interface, is referenced to a user selected datum. GPS Utility ASSUMES that you have set the same datum as the GPS unit and displays the altitude as received over the interface without change.
GPS Utility displays the altitude as an 'ellipsoid' height. It does not have a 'geoid' height model which would account for local variations of the gravitational field. Mean Sea Level may differ from the the ellipsoid surface by a number of metres. Over a local area, this offset will be fairly constant.
As GPSU does not have a geoid model, you should set GPSU to the local datum before you download data from a GPS receiver. The geoid height and local datum height are normally very similar. If you need to re-reference or adjust the height information then you can use the Calibrate Altitude tool in GPSU.
Check download page in this link: gpsu.co.uk/download.html
Keep in touch.
Posted on Mar 22, 2011
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
I am looking for an amplified TV antenna to receive several stations within line of sight about 20 miles away.
I have an ordinary antenna for digital TV and use an ordinary amplifier that one end fastens up within six feet of the top of antenna and the other end plugs into an electrical receptacle in my house and both ends are right on my antenna wire that hooks to my tv. I live 80 miles from Detroit Michigan and across Lake Erie from Cleveland Ohio and I get 50 channels on my tv. all the time
Apr 12, 2015 | Televison & Video
We purchased a house with a 60-inch Wolf range. Our problem is that the igniters function, but it takes several seconds before gas flows to the burner. Once one of the burners is on, the others come on...
Yall might have to install a special kit for higher elevations. The stove might be rated for higher elevations but is it tweaked for that ? Not hardly. Most stoves come for set for normal conditions. I bet yall need to add a high elevation kit.
Ask em
Mar 16, 2011 | Viking Kitchen Ranges
Total elevation gain consistently way too high (20+ percent)
I have the same garmin, and have the same problem.
The high changes even during flat runs so when added you have this overamount of climbing.
I just reduce the points of the track and then the addition is more accurate.
My problem now is that the GPS stops working during runs (turns itself off). Awful!!!
Aug 03, 2009 | Garmin Edge 205 GPS Receiver
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
How do I change my garmin forerunner 205 from miles to kilometers
To change this setting go to the menu on the Forerunner by pressing the Mode button then follow the steps below:
  1. Select Settings
  2. Select General
  3. Select Units
  4. Select Distance and/or Elevation and change this to Metric if you wish to see the measurement units in kilometres and metres, select Statute if you wish to see units in miles and feet
Jun 21, 2009 | Garmin Forerunner 305 GPS Receiver
Need map updates for GPS
Dependant on the type of unit you have, you can order MMC or SD cards from several companies. I have used Navionics with much success. They have a buy-back program where you can get a discount towards the latest cards when you turn in your old ones. Also, if you have a memory card device, you can access tons of lakes directly from the Lowrance website. Then save to acard and load into you boats unit.
Triton72
Mar 25, 2009 | GPS
Magellan 315
That unit does not have a touch screen so holding the screen while powering up wont do anything. I'm not sure which key it is on that model, but to do a reset you hold down one of the keys while powering up. Try holding down the enter key while you power up. If that doesn't work, try again with the other keys until you find it. If it doesn't reset, you may have a dead keypad.
Jan 25, 2008 | Magellan GPS 315 GPS Receiver
Wrong elevation showing garmin etrex vista
Found a fix, by resetting all user data my problem was fixed.
Garmin Edge 305 Power off device and hold 'mode + power'
eTrex Vista Power off device and then hold 'page + enter + power'
Hope this helps!
Dec 16, 2007 | GPS
"NO POS"
Have you gone through the "Initialize" process again? If the memory has been cleared you will need to re-initialize. Refer to page 4 of your manual. Power On > Select Language > "ENTER" > INITIALIZE screen > "ENTER" > Select Region > "ENTER" > Select Area > "ENTER" > Enter Elevation > "ENTER" (if you don't know elevation, press enter) > Enter Time > "ENTER" > Enter Date > "ENTER"
Jul 05, 2007 | Magellan GPS 315 GPS Receiver
GPS Logo
29 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
