Question about Dishwashers
When you pick a program close the door nothing happens.
  • 822 Answers
If power is right.then check water is on.....you can get a faulty water connecter both at the pipe and inside the machine......
cheers
Posted on Mar 22, 2011
Aeg micro wave 153 e. unitis programmed door closed. lite goes on. nothing else happens
It may be a door switch. Bad magnetron, or bad control board.
Oct 12, 2014 | Microwave Ovens
Why won't washing machine start?
It is most probably the door sensor that is faulty. If the sensor does not sense the door closing the machine will stay in "open door" mode and will not start with it's program.
If the machine is still under warranty, take it in for repair or have someone check it out for you. It should be a quick fix, if parts are available.
May 24, 2014 | Washing Machines
Have power but won't start
All automatic washers are programmed to "latch" the door closed before it will move the basket. Check to see that the latch is engaging the door.
Jan 14, 2014 | Samsung Washing Machines
The programe wont stars
Dear Sir:
You must fit very well the door catch. The switch is the elements most important for to run the dishwasher. Otherwise you must waste your time.
See the diagram attached, and you will the switch door must be close for to close the starting relay for RUN the main motor.
sincerely. God bless you
May 04, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
Does not start. Cannot change programs
What is the manufacturer and model number of your dishwasher?
Approximately how many years old is it?
Are you saying the water never enters the dishwasher, even on the one program that you have?
Apr 11, 2009 | Dishwashers
When I key in the code the garage door closes, but when I key in the code to open the door, nothing happens It is actually a Skylink garage door opener but unable to find in the selection list
MANY UNITS NOW HAVE A ONE BUTTON CLOSE FEATURE. THIS WILL CLOSE THE DOOR WITHOUT PRESSING THE PROPER CODE.
HOWEVER, IT WILL NOT OPEN THE DOOR WITHOUT THE PROPER CODE.
SOUNDS LIKE YOU HAVE A REMOTE THAT WILL SEND A CODE AND CLOSE THE DOOR. IT MAY NOT BE ABLE TO BE PROGRAMED TO OPEN THE DOOR. YOU CAN GET AN EXTERNAL UNIVERSAL RECIEVER IF CHAMBERLAIN OR LIFTMASTER ARE ON THE LIST THAT WOULD WORK.
HOPE THIS HELPS
Jun 29, 2008 | RCA Universal Remote Control
Front load washer doesn't turn itself on when door closed and cycle picked
First check the door if it is still properly aligned try to tightened first the two screw of the door sometimes it is loose align it, reset your machine, if it is still the same, now take a look on the rubber gasket attached to the shell cabinet, there is a big plastic clamp or a rounded wire with spring on the other end it is the gasket lock, pull it u can return it by reinserting it back, wire lock-just stretch it and put it back,after doing that-pull the gasket slowly,to your right the door lock is located, check if it is misaligned-difinitely no problem with your door lock it is a matter of alignment - happy washing
Apr 06, 2008 | Washing Machines
HELP!!
Need to check the door lock and door switch. Nothing happens if the machine thinks the door is not shut or locked.
Feb 29, 2008 | Washing Machines
Nothing happens when i open or close it
it usually happen when you accindetally dropped it... thiers a little thing which i called it a little magnet...this magnet serve as your door man...when you go out he will open it for you and if go in he still do same things.. well i mean check this little thing .. if he still there in his position...replce it when it gone..
Nov 21, 2006 | Samsung SPH-a620/VGA1000
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
