Question about NewCon Optik BN-5 Binocular
I can't figure out how to dismantle the eyepieces on a pair of 10x80 WW2 German luftwaffe binoculars to get at the lenses
  • 112 Answers
There should be a beveled lock ring on the eyepiece.look at it closely...there should be numbers or letters on it...now turn the eyepiece in half way....hold the eyepiece with one hand and wrap a piece of rubber cord around the the bottom of the eyepiece that has the numers or letters on it and twist ,,,it should come apart...the eyepice is actually two pieces the problem is sometimes you will have to apply a little heat to break the seal do not use pliers or it will damage them ..if i can talk you through it i will.. give me a call at 5088330650......www.reichinstruments.com
Posted on Aug 17, 2008
How do i dismantle a canon 15x50 is binocular
On standard binoculars the main lens housings unscrew fairly easily with just hand pressure and the eyepiece lenses sometimes need a small screwdriver to release a locking screw before unscrewing.. I have never yet had compact binoculars apart so I can't comment about those.
Binouculars are assembled in conditions that would make the average operating theatre seem grubby by comparison. It is not wise to dismantle binoculars unless absolutely necessary and then only to do so in very clean and dry surroundings, avoid touching the lenses to avoid marking the coatings and most importantly don't touch or disturb the prisms. Recorrelating binocular prisms is a skilled job requiring much patience and ideally the use of specialist equipment.
The service is not easy to find and not cheap either.
Jul 23, 2016 | Canon Office Equipment & Supplies
How to hold binoculars properly
1. Remove the lens covers, if they are in place.
2. Set the diopter on the right barrel eyepiece. The function of this setting is to adjust between vision differences between your eyes if you are NOT wearing corrective lenses. Set to zero if you do have corrective lenses on (glasses or contacts). For proper diopter adjustment see this article: Binocular Selection Guide.
3. Most binoculars will hinge in the middle to allow for differences in the spacing between the eyes. Set the spacing to fit your eyes.
4. Adjust eye cups. Each eyepiece will have a means of maintaining the correct eye relief for the user. On quality binoculars the rim of the eyepiece will extend and retract as you twist the eyepiece rim. Move all the way in if you are wearing eyeglasses or adjust out if not wearing eyeglasses. You will know if they are set correctly when you look through the binoculars and check to be sure that the circular edge of the view should be sharp and not fuzzy. At this point we are not looking at any object in the view but rather the perimeter of the view. You may need to adjust the eye cups again to compensate. On lower cost binoculars the eyecup may only be a rubber lip that you either fold over (the "in" position) or out.
5 Raise binoculars to your eyes and use one finger to adjust the focus wheel on the center shaft between the two barrels, until the view is in sharp focus. If viewing for extended periods you may want to keep your elbows down near your side as this will increase comfort while viewing.
Final safety tip: Do not look at the sun through binoculars.
Many people enjoy observing nature with binoculars. Having them handy is key. Hunting, astronomy, marine use, and stadium sports are a few more activities where having a pair of binoculars can make a real impact to your experience.
Mar 06, 2014 | Zeiss Optics
Blurry binoculars
Unfortunately, the reason for the blurryness is that the binoculars will not focus. Either the lenses have become dislodged, or something is obstructing the full motion of the eyepiece lenses.
I tried to fix a pair of binoculars that had the same problem and finally gave up.
You will probably have to get them professionally repaired. Be sure to get an estimate first, though, because the repair cost may be more than the binoculars are worth, depending on how much you paid.
Wish I had better news!
Jul 14, 2011 | Optics
I wear glasses. I can't see through binoculars with glasses on or off.
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
Oct 12, 2009 | Bushnell Optics
I see 2 planes of vision on my 8x24 weaver binocular
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Sep 28, 2009 | Weaver 849433 (8x24) Binocular
Each eye is clear, but they aren't lined up right...it is like being crosseyed.
Hope this helps...
Sep 26, 2009 | Nikon Travelite V Binocular
Double vision in minolta binoculars
Hope this helps...
Aug 30, 2009 | Minolta Activa Standard Zoom Binocular
Cannot get them into clear focus
Hope this helps...
Aug 17, 2009 | Swarovski Optik Optics
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 | Optics
NewCon Optik BN-5 Binocular Logo
136 people viewed this question
Top NewCon Optik Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a NewCon Optik Optic Expert? Answer questions, earn points and help others
