Question about Ducane Grilling
Burners will not ignite when starter is fired
    Brigadier General:
  • 4,736 Answers
Are you able to match light the burners? Is there any gas getting to the burners?
Please advise by clicking on the comments link.
Posted on Mar 22, 2011
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
The starter button does not seem to be igniting the propane
Its not, and this is common after about a handful of uses. The igniter is covered with sooot or grease or broken. They sell universal igniters at Sears for like 3 or 4 dollars. Your only other option is to strike long length matches and use those to light it. Be careful , always stand back when lighting grills or any kind off fire. hope this helps.
Jul 20, 2010 | Weber Genesis Silver B Grill
The electric starter on my cooktop started smoking (electrical fire). How do I replace it?
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jul 17, 2010 | GE 30 in. JGP336 Gas Cooktop
Need to manually light the grill as the starter is not working
Is the igniter sparking? Some are battery powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece.
Hope this helps! Douglas
Jun 03, 2010 | Fire Magic 11-S1S1N-A Stainless Steel Gas...
Electric spark starter on one of the burner runs continuously
check the spark head on that particular burner first for dirt,they all need to be clean to recognize the flame after ignition and sense the flame to shut off the sparker module after ignition,and if not you will need to replace the spark module that fires the sparkers itself,but try cleaning sparkers and underneath where the wires connect to the sparkers first for contamination,its cheaper than starting to replace parts
Dec 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The grill will only start with a fire starter at the end of the b
At Weber, we believe everyday is a good day to grill, so we stand ready to answer your questions and impart advice from 7am to 11pm CDT/CST. Call us at 1-800-446-1071, and one of our grilling experts will be there to help you seven days a week.
Jul 16, 2009 | Grilling
I can't get the rotissorie burner to light. I have gas, all of the other burners light, the igniter sparks. Just can't get it to fire.
first turn your rotisserie knob on and then push it in, hold it down and push your starter while you hold it when it lights keep the knob down for about 15 to 20 seconds it should do the trick
Jul 12, 2009 | Ducane 30400042 (LP)
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Grilling Logo
293 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
