Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What would cause an unbalanced load condition in a whrilpool washer model wtw6400swd . Unbalanced when empty and legs leval!
    Brigadier General:
  • 6,277 Answers
Although you say it's level I would recommend you try all of my method to make certain, please;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 22, 2011
LG WaveForce top load washing machine flashes unbalanced on every single load. Even when run completely empty. a single load can take up to 6 hours to complete.Manufacturer nonresponsive. Solutions?
LG issued a recall on certain waveforce washers due to the unbalanced error codes. You may have a washer that is affected. Contact LG at 855-400-4639, and have you model number and serial number at hand to see if you need a software update.
Jan 25, 2016 | LG Washing Machines
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
I have a Samsung washer front loader it vibrates really bad when it is on spin cycle model #wf409anw/xaa
To test whether the problem is caused by a fault in the machine, or the way it's being used, run it through a complete empty cycle. No clothes, no detergent.
If it still vibrates under those conditions, call a repairman. If not, then the cause is an unbalanced load. This often happens when dis-similar weight articles are placed in the washer at the same time - such as bath towels along with tee shirts, etc.
Dec 12, 2014 | Samsung Washing Machines
Whirlpool awoe 8761
Is it always loud or just when it is a full load. If the load is unbalanced it will be loud. Most F/L washers today have some kind of unbalanced load detection, but they are not all that great. If it spins quietly when empty it is just an unbalanced load. Don't over load and don't mix rugs with clothes, pillows, etc...
May 19, 2012 | Whirlpool Washing Machines
Ul keeps coming up i saw solutions about popping off cap but my carbrio doesnt have a cap
The UL means UNBALANCED LOAD
The washer tries to balance the load automatically as soon as it has detected its off balance and the tub is wobbling. IF you find that the load isnt unbalanced and it keeps coming up(try a load without any clothing) the control board would need to be replaced.
Of course though try seeing if the legs need to be adjusted to level the washer.
Good luck,i hope i have helped you to undestand what is wrong with your washer,
Gene
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Always unbalanced in the spin cycles
the machine may need to be releveled, if it is not level the clothes will have a tendancy to go to the low side and thereby causing the unbalanced condition
Mar 20, 2011 | Haier XQBM22-C Top Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Spin Shake ...
yes the water is supposed to be there, thats called the balance ring, some machine use cement others water. you say the washer is unbalanced even when empty, is there an indicator or is the machine itself physically off balance. if there is an indicator the off balance swich might have gone bad or you might need to adjust the leveling legs.
Jul 03, 2007 | Frigidaire CWS3600AS Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
160 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
