Question about D-Link AirPlus DI-524 Wireless Router
Cant access AirPlus DI-524 Wireless
I upgraded the firmware (english version - default was german) and it worked just fine. After I restarted the router I couldn't access it. DHCP doesent work, so I entered the ip address manualy example 192.168.0.10 gateway 192.168.0.1 after that I ping 192.168.0.1 and it is successfull, but I cant access the web interface. The status light is blinking, and WLAN is off. I did a portscan and no ports are open...Can you please give me some directions how to deal with this. Thaks in advance. Looking forward to your replay.
  • Boban Jovanoski Aug 04, 2008
    How can I refresh/reload the firmware without accessing the web interface to the router.
    I've hold the reset button for 20 seconds, turned it of (still holding), turned it on and another 20 seconds.....pour reset button
    P.S. All firewalls are down
    Problem Solver:
  • 11 Answers
Kick it
Posted on Dec 24, 2008
  • 35 Answers
Hello.
The router's software got corrupted which affected some of the feature on your router such as DHCP or the wireless. The only way to do it is to reflash/reload the firmware of the router then make sure you reset it back to its factory default. After that, it should work unless there is a problem already on your device.
Posted on Aug 03, 2008
I have a d-link DI-524 router but the firmware is in geman, how can I change it to English?
First, download the English firmware for your model.
Then install it on your D-Link. To figure out how to navigate around the German interface, use the D-Link emulator here to practise on an English equivalent (just click OK at the Login prompt).
Essentially, you'll be going to the fourth button on the left-hand side (Firmware), then hitting the Browse button in the middle to select the firmware file you downloaded to your local hard disk. After that, just follow the steps.
Nov 01, 2010 | D-Link AirPlus DI-524 Wireless Router
D-link error from broken upgrade
there should be a tiny hole in the back where you can fit a needle inside it, that will reset it to defaults.
Jun 05, 2010 | D-Link AirPlus DI-524 Wireless Router
Can't Connect to Internet Using DI-524
Most routers the default address is 192.168.0.1 unless you havve a modem that takes that address.
Sep 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Slow connections
many routers have problems on firmware upgrades in regards to configuration data. You should try to reset the routher to factory defaults (the firmware upgrade will still be fine) then put in you old configuratin information in for the reset.
Aug 25, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router pass and username
Default IP: 192.168.0.1
Default username: admin
Default password: *blank*
Jan 22, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 status led not blinking
Here are the instructions
  1. Make sure that you have a copy of the latest firmware and it has an *.exe file with it. Because the router's configuration page won't be available, you'll be needing the exe to some sort of force the firmware upgrade procedure.
  2. Unplug everything attached to your router except the power cable and LAN cable connected to your pc.
  3. Configure your TCP/IP with this info: IP:192.168.123.253, Default mask:255.255.255.0, Default Gateway:192.168.123.254 and DNS Server:192.168.123.254 (Use only 1 DNS server). Save this new configuration and reboot your pc.
  4. Unplug the power cable to your router as the pc reboots. When everything is up and running, plug the power cable. The status led will be flashing like crazy. It's normal.
  5. Use the exe file to upgrade your firmware. Make sure that the utility file (exe file) is able to recognize your router or else you won't be able to do a firmware upgrade. Now this may take a while, keep pressing the Refresh button to recognize your router. Once recognized you would see there 192.168.0.1 crash. Once you have this, you can now press the upgrade button.
  6. Wait for a while until the unit finishes the upgrade and once done, I think you have recovered the life of your router from the pits of hell. Hahahaha.
  7. You can now unplug the power of the router and restart your pc, see if everything is doing fine.
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
Nov 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI 524 Frequent Wireless Network Loss
Try changing the channel of your router ex (channel 1-6-11). Since you upgrade the firmware of your router you need to reset it to factory default and reconfigure everything so the new firmware will take effect.
May 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Configuration as "Client"
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
142 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
