Question about RCA Microwave Ovens
Power works, everything seems normal but no heat
  • 604 Answers
Microwave ovens do not produce heat, they produce microwaves. the heat comes from whatever is excited by the microwaves. In your case i would bet that the magnatron (microwave tube) has become defective. If this oven is less than 5 years old, the magnatron may be under warranty. depending on the model it may be repaired at no cost to you. In the case of Kenmore (Sears) you would take the oven to their customer service dept and they will send it in for you for evauation. they will charge you $50.00 US this amount will be applied to the repair if you choose to have it fixed. If the Magnatron is bad and is under warranty, they will fix it, and return it to you along with a refund of you $50.00.
Posted on Mar 22, 2011
Maytag microwave mmv4184AAQ not heating
The common reasons are a shorted diode many use, the inverter board used for control and power, and the Magnetron which does the work
Dec 07, 2012 | Maytag Appliances Over-the-Range Microwave...
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Everything on oven appears to work, but does not heat.
from what your describing it sounds as if you have burnt the antenna off of the end of the magtube if this is the case if your microwave is no longer under warranty due to the cost of the part you may be better off to purchase a new microwave.
Mar 25, 2009 | GE JE1540 Microwave Oven
EVERYTHING WORKS NO NOSIES SOUNDS LIKE IT IS WORKING WILL NOT HEA
could be the power fuse inside the microwave, you have to remove the casing to access these.large power fuse would seem to be the problem, this is normally 10 amps but could be 13 amp. there is also a control fuse that control the power relays
if this is blown the relays could be at fault
Feb 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Everything works but the heat! Any suggestions?
door micro switch open/need to replace / if that open the magnetron will not power no heat will produce.
Jan 02, 2008 | Whirlpool MH1150XM Convection/Microwave...
Microwave Ovens Logo
301 people viewed this question
Top RCA Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Andrew Taylor
Andrew Taylor
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
