Question about Grilling
I have noticed that two of the burners will not ignite. I do not believe that the gas is going into the burner, as the igniter fires, but the burner does not light from it. I have replaced the burners several times and cleaned the grill, as instructed. The grill is approximately 5 years old. M Wells
    Brigadier General:
  • 4,736 Answers
Are you able to match light the burners?
Posted on Mar 22, 2011
Maytag dg313 series 7 dryer will not light
Thermocouple. The igniter heats the thermocouple to turn on the gas valve and fire the burner.
Nov 29, 2013 | Dryers
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Oven has small explosion igniting and going off. says tj
A few years back I helped a neighbor with this same problem in a forced air, gas fired, "horizontal" furnace in his attic.
After having him cycle the thermostat a couple dozen times while I watched through the opening in the side of the furnace, I finally figured out what was happening.
First, there were about 6 cast iron burners [about 14 inches long with two rows of gas holes along the length]. These burners were parallel to each other and oriented perpendicular to the long axis of the furnace.
The gas was fed to the ends of the burners with a pipe manifold. The standing pilot light was at the center between burners 3 and 4. Due to the spacing distance between the burners, the pilot light was too far from even burners 3 and 4, the flame could not "jump" to ignite them, or any of the other burners. The manufacturer had installed a thin sheet metal "tent" which ran from the gas entrance end of burner 1 to burner 6, and was about 2 inches above the burner, AND the pilot light.
The standing pilot was on all the time. When the gas control valve turned on, gas began to come out of all the burners at the same time. Naturally it came out of the gas supply manifold ends of all the burners.
The "tent" captured that gas coming from the burners and "filled" up to over the pilot light which ignited the gas at that point, and the flame would propagate along the tent to ignite the gas coming out of all of the burners.
In my neighbors case, the tent had somehow become dislodged so that it did not cover all of the burner ends. For those burners which it did cover [including the pilot light] it caused the burners to light properly.
For those burners who's ends were not covered, and who's gas could not be captured, they would NOT ignite simultaneously with the others.
As these burners WERE feeding gas into the combustion chamber, the gas "envelope" would spread until it reached the nearest flame ignition source, at which time the entire "bubble" of gas would ignite with a minor boom [actually a low energy explosion]. Flame would momentarily shoot out of the burner chamber opening, and from that point the furnace would operate normally until the next restart cycle.
Although there could be several causes, I suspect that the symptoms you describe are the result of DELAYED IGNITION of some or all of the main burners.
IF this is the problem, then the solution is to clean all the burners [including the burner outlet holes in the ignition ends of the burners], clean out the burner compartment, AND properly adjust the orientation of whatever system [you have to evaluate how it works from analysis of YOUR furnace] your furnace has to ensure all burners ignite as close to the same time as possible.
When operating properly, the ignition should be a smooth transition, burner by burner, from the pilot to the farthest burners. In other words. the ignition will "flow" from the pilot outward to each adjacent burner until the farthermost ends ignite last. This usually doesn't take more than one or two seconds at the most.
Unless you are an experienced handyman, and understand this analysis and instructions, I strongly suggest that you engage the services of a professional furnace technician.
Feb 13, 2009 | Imperial Commercial Cooking Equipment...
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS stove igniters clicking
Actually Dave, when you turn on one burner, all of the igniters do fire. This is normal. Perhaps you never noticed it before. regards, Joe
Dec 19, 2008 | DCS RGS-486GD Gas Kitchen Range
Ignition
When you turn the gas valve to High or Ignite position..do you hear or smell gas going into the gas burner? If yes, then look at the position of the igniter in respect to the gas burner to see if it generates a spark either with or without gas running.. .. if you have gas entering the gas burner.. and if you've used the Grill a lot.. the jets may be clogged and need cleaned to allow gas flow thru them.. if the jets from the burner are clogged in or near the igniter..it may not ignite easily untill you get lots of propane in the area.. Check the gas jets to make sure you have gas coming out and then check the igniter to make sure it generates a spark.. Hope that helps..
Aug 28, 2008 | Weber Genesis Silver B Grill
Whirlpool super capacity 465 / gas oven won't light
now you say your top burners aren't lighting well either have you noticed any difference in the flame height if you turn all the burners on all the way
Jan 17, 2008 | Ovens
Grilling Logo
142 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
