Question about Troy-Bilt Garden
I want to Greese the rear tines! there is no oil or greese screw to fill or drain whats the deal
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
On a troy built rear tines are lubricated by the transmission oil. You will find a pipe plug usually 1/8 in with square head on the side of trans. near wheel axle.
Posted on Mar 27, 2011
Engine lite on allso my i have coolant problem every i saw greese in my coolant i cleen it it come right back help me please
Doesn't sound to good. A cracked head between cylinders will put oil in water...Check your oil dipstick to see it water is getting in oil.
Aug 12, 2013 | 2003 Chevrolet Malibu
Sounds like it needs a lube job.
you need to be more informative in your postings,,,generally when you turn the steering wheel,,you will hear a squeak,,,that tells us we need greese,,,but the newer vehicles have no greese zert's,,,so usually ball joints need replaced,,,rather costly to pay for but not so bad if you do it yourself,,,of course after,,,re-allignment is necessary,,,or if accessable,,you can drill and put greese zerts on yourself,,,takes time,,,but do'able.
Mar 12, 2011 | Ford Explorer Cars & Trucks
My car is experiencing seaking noises whenever i ride over bumps. I was wondering how to grease that problem.
It could be your shocks. You just need to greese all your joints on the axle. Greese your wheel bearings, balljoints, tie rod ends, and the universal joints. You just need to jack one side up and go to town on them parts. Just where a part can pivot Todd, greese it. It can't hurt. Most the parts should have moisture spots at them anyway from prior greese. Just look for those spots if your not sure. If you have a question, just let me know.
Mar 04, 2011 | 2006 Chrysler 300
Does the rear wheel bearings on a fully floating axial require packing with grease or are they lubricated with the gear oil from the differential?
NO GREESE NEEDED. BUT I DO PACK SOME GREESE IN THEM IF I HAVE THEM APART. JUST MAKE SURE REAR DIFF. IS FULL.
Dec 19, 2010 | Ford F-250 Cars & Trucks
I have a Miele silver moon that kept shutting off while using it. I replaced the hose with the new 125-s model but problem came back. It does appear to be a problem with the hose. Any suggestions?
My S558 Red Velvet had the same problem. I disassembled the handle and cleaned the rings and electrical contacts. The problem has not come back.
Sep 28, 2010 | Miele s558 Silver Moon Vacuum
Type of lube required in 2006 colorado two wheel drive ext cab?
if you change your oil every year/10k then 10/40 semi is fine.
Sep 11, 2010 | 2006 Chevrolet Colorado
Manual transmission / what oil/greese goes in ??
WHAT I USE IS 80W 90 GEAR OIL.THERE SHOULD BE A BIG SCREW ON TOP OF THE TRANS AND THIS IS WHERE YOU SHOULD PUT THE GEAR OIL IN.HOPE THIS INFO HELPS.TAKE CARE AND GOOD LUCK, MANNY
Feb 25, 2010 | 1996 Geo Prizm
85 nissan 300 zx turbo throttle probs
check the connector for the MAF mass air flow sensor and TPS throttle position sensor. Unplug them and look at the terminals to see iof they are green with oxidation. if so, clean them with a tiny file, like a fingernail file but narrower, or jewelers file. somthing that will fit into the plug and scrape the crust off the contacts. after that, fill the plug and sensor with dielectric greese, like silicone greese they use for spark plug wire boots.to seal out the moisture.
Dec 09, 2009 | 1985 Nissan 300ZX
Garden Logo
157 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
