Question about Ryobi Saws
Ryobi compound miter saw Model TS1341 To rotate the table assembly on the base to change angle of cut is very difficult. The table assembly and base are aluminum that slide or rotate against each other with no bushings or friction reducing mechanisms. Is there a cure or fix-it kit available ? The saw is 3-4 years old, but has not had a lot of use. Thank You, Bob
  • 604 Answers
You might try some silicone lubricant spray (available at auto supply) the stuff is very slippery. spary a little on the underside parts that rub on one another, try not to get any of the silicone on the top parts of your miter box as it will get on the wood that you are tyring to cut and it will leave a stain.
Posted on Mar 23, 2011
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
What is a compound miter saw?
A compound miter saw has a rotating vertical pivot allowing the cutter head & blade to be tilted (or beveled) sideways in addition to the horizontally rotating table. This allows vertical & horizontal angled cuts as well as cuts angled in both planes.
Jan 28, 2013 | Saws
I bought the 10" compound
I have been in the same situation in the past, with a mastercraft miter saw to a point of using playing cards to get that nice tight miter joint. placing the cards between the fence and the piece i was trying to miter.Rioby makes mastercraft all thought they are a good saw they have their limits to the precisions of their cuts. good for fences,decks, stuctural framing ect, were a degree two is not a big thing,but when making furniture or interior trim work or picture frames or hobby craft you need to buy a good pro saw like a dewalt or bosh sliding compoud miter saw they may cost more **** their worth the money they are very precise and will last a life time if taken care of .It will be worth the money when you get that perfect cut every time you use it,it will put the JOY and fun back in your projects and not to mention qualaty in your master pieces.
Apr 01, 2011 | Ryobi 10 In Miter Saw With Laser
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
How to turn the base for compound cuts
Is there not a piece metal at screw handle to push down on top,or pull up on bottom, then rotate?
Jan 13, 2010 | Saws
How do you adjust the saws angle cut? When it is sett at 0 degress it is not making a square cut.
take a framing square sit it on base plate and adjust till its square and level with that angle.works same with table saws also hope that helps ya
Nov 28, 2009 | Hitachi C12LSH 12" Sliding Dual Compound...
The table binds when I rotate it to change miter settings. When I cut miters(45 degree) I'm not getting straight cuts along the edge. The saw is on a plywood base mounted to a Dewalt miter saw stand. I...
Could be the wear plates under the table between it and the base. Or if it doesn't have any then the two mating surfaces are dry and rubbing causing this problem I would suggest going to Dewaltservicenet.com and typing in your model number and downloading a breakdown for the tool. To remove the table on most saws you have to remove the fence and that requires that you square everything up upon disassembly. Let me know and I will try and help further. By the way to clean the parts I use a surface conditioner with something like a scrubbing pad and then after everyting clean use a dry silicone lubricant or equivelant.
Sep 13, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Cannot rotate the Dewalt 708 mod 3 saw horizontally
If you have loosened the handle a little and pulling the adjustment trigger didn't allow for movement,you may need to remove and clean the turn table.(don't forget,the handle must be loosened for the turn table to rotate)
Please rate this a fixya
Feb 09, 2009 | Cross Dewalt& 12" Double-Bevel Compound...
Saws Logo
188 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
