Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
The door suddenly will not close on its own and we have to be sure to close it properly every time we open the fridge. It is on wheels and we need to know how to level the fridge so that the door automatically closes again
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Your lower door cams likely need replacing. They are at the lower hinge of each door.
Kelly
Posted on Mar 22, 2011
The freezer door is on the bottom and will not stay closed. If i lift up on the door just a little and push hard it will close but will pop open as soon as i let go.
I would check and make sure that the fridge is properly leveled, and also that there is nothing behind the fridge or the freezer compartment that is preventing it from closing properly.
May 25, 2015 | Refrigerators
The refrigerator door does not close properly to make a seal. i have to lift the door up by the handle and close it to get it to seal and turn off the inside light. the door has dropped significantly. i...
There should be a hinge plate on the top outside of fridge and at the bottom. Loosen these then close the door and make sure it is seated properly. with door closed tighten top hinge mount the open door if needed to tighten inside mount. May need to be done a couple of times to get correct fit
Jan 10, 2011 | Hotpoint Refrigerators
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Our N369B fridge freezer has a large amount of ice clinging to the upper back of the fridge how do we stop this happening?
Your freezer door is not closing properly. if it is not on wheels then make sure the bottom nut that also holds the front wheels or slider in place is tight. Also maybe have the seals replaced and check door alignment on both doors. You will of course have to defrost the freezer.
Oct 27, 2009 | Fisher and Paykel Active Smart E522B...
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Maytag MSB2354DRW
If door does not close at all, even if you push you need to replace the door pickoff.
If door stick a bit but does not stay closed you have to replace the door seal.
Here you find all diagrams for your appliance
See also here, there is seal and pickoff for the freezer, you can buy them from this site.
Aug 26, 2008 | Refrigerators
Fridge not cooling properly set all the way to coolest setting freezer seems to be cooling ok
check coils underneath may be dirty, if frost in frz. back wall then you have a defrost problem. make sure door was not left open (accidently). make sure door closing properly and gasket is sealing properly. check to make sure light turns off when door closed. hope this helps if not contact us with any additional info. needed. thank you for your time.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE # 8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair
EMAIL custmomerservice@allbrandsappliancerepair.com
Jul 11, 2008 | Whirlpool Refrigerators
Liftmaster security + model 1265 NOT CLOSING PROPERLY
wbuero, I had same problem two weeks. The door springs weaken over time and may need to be tightened - check opening force manually. Manufacturer also recommended reviewing install guide to be sure opener arm is attached at proper angle. The opener on my professionally installed door was not connected properly. It that doesn't work, the opener drive train or door track/wheels may need maintenence.
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
172 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
