Question about Whirlpool Duet GHW9150P Front Load Washer
In some cycles the word sud appears on the display. Then the cycle will stop and F35 appears on the display.
  • 1,998 Answers
One of our techs has already answered this on the f35 error code click here http://www.fixya.com/support/t400054-error_code if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
p.s to repair this issue you would replace the analog pressure switch the switch's part number is W10156252
Posted on Mar 22, 2011
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
The word SUD appears and then the cycle goes to a F35 signal. After a period of time it shuts the machine off. Doesn't do it all the time. I have never used any soap powder but HE.
When you get f35 and sud. It usually the pressure switch located under top cover right side very rarely its the main board but I have seen both cause problem
Jun 19, 2015 | Washing Machines
I have an HE 5T Steam Front Loading Automatic Washer. It is showing Sud indication, nothing seems like happening and after few minutes it will show F35. What does it mean?
Hello again,
I found your manual. If you like to get it, go HERE. This is what it says about "SUDS" action:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Near the bottom of the troubleshooting page, it gives this for errors:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
It doesn't specifically state what "F35" is, so I can only suggest these steps, and see if this solves your problem. If it doesn't I would be inclined to believe that there is a problem with a part, which would probably be serviceable by a tech from Sears or their partner service company.
Hope this clears it up for you.
Please rate and comment. Thank You
Joe
Sep 02, 2011 | Kenmore Washing Machines
Washer is vibrating badly. it shows a cod f35
The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle.
Jan 10, 2011 | Kenmore Front Load Washer
I have a whirlpool WFW9600TW01 front load washer. It is giving F35 and SUD error codes. I have cleaned the drain pump and lines, cleaned the dispenser, flow regulator and hoses, took out and cleaned the...
Hi dear.I may have solution for the SUD error.You can give it a go.But I do not know any thing about F35 one
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component.
As it says run couple of rine cycles it should get back to normal.I hope that helps you.Thanks.
Aug 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Suds, and F35 keeps coming up when trying to wash!
I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
Jul 26, 2010 | Kenmore 44102 Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Aug 02, 2009 | Kenmore Washing Machines
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal De
