WHEN i BOOT UP MY COMPUTER IT STARTS THEN AFTER A FEW SECONDS IT CLOSES DOWN AUTOMATICALLY
    Problem Solver:
  • 26 Answers
This behavior on your PC can only be caused by a malware/worm/trojan/virus. If you can no longer start any applications because it quickly shuts down, the only solution is to re-format and re-install your computer. If you still have a chance to run system restore, then restore it to a point where it is still working properly.
Posted on Aug 03, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
The light is flushing and when i open it ,after a few minutes it close automatically
If it closes few seconds, it's indoor coil sensor problem.Replace new sensor. If it closes within few minutes, No communicationbetween indoor and outdoor. Check PCB.
Dec 28, 2010 | LG LSC121PMA Split System Air Conditioner
I have DG31PR Original Motherboard with the system. I have installed Two HDD in the system Now i Want to change the boot order without entering BIOS Setup. Is it possible to press some function key like F7...
I assume you're wanting to automatically boot a different hard-drive? If so, it's a real simple fix. I'll take you through the steps using Windows XP Professional. In the example below we will tell the system to automatically boot Windows 7 if the user does not make a choice in 30 seconds.
1. Open My Computer.
2. Open your C:\ drive.
3. At the top, select Tools -> Folder Options (Picture)
4. Select "Show Hidden Files and Folders," Uncheck "Hide Extensions for known File Types," Uncheck "Hide Protected Operating System Files." (Picture)
5. Locate "boot.ini." (Picture)
6. Right-Click boot.ini and go to "Properties." (Picture)
7. Uncheck "Read-only" and press OK. (Picture)
8. Open boot.ini
9. Find the line corresponding with the system you want to boot automatically every time your system starts. (Picture)
10. Place the system's path into the "Default" slot. (Picture)
NOTE: Only place the system's path into the default slot, not the boot options and description!
11. Save the file and exit boot.ini.
12. Once again, right-click boot.ini and go to Properties. (Picture)
13. Check "Read-only" and press OK. (Picture)
14. Restart your system to ensure the changes were made correctly and that your system starts the correct operating system.
CAUTION: Altering the lines below "[operating systems]" can change the way you system starts and might prevent your system from starting! DO NOT ALTER ANY ENTRIES BELOW "[operating systems]" UNLESS YOU ABSOLUTELY KNOW WHAT YOU ARE DOING! Altering the "Default" slot will not harm your system as long as you enter a system path that is described in the "[operating system]" sector.
Altering boot.ini the way we just did tells the system to automatically start Windows 7 if the user does not make a choice in 30 seconds. Additionally, if you want the timer to run for say 1-3 seconds, you can alter the "timeout" value to read something similar to: timeout=2
That way when the system will automatically boot the "default" system in 2 seconds if the user doesn't make a choice. NOTE: Don't forget, you can't alter boot.ini unless "Read-only" is unchecked. Also, don't forget to check it again once you're finished editing boot.ini.
Let me know if this solved your problem, or if you were wondering how to do something else.
Jan 01, 2010 | Intel Computers & Internet
I have a 1780U. When computer starts up the
What I have done is boot the computer then wait a few seconds then reset it. That usuallu gives the monitor enough time to wake up so you can catch the bios info. It may take a few times to get it to behave but this works.
Nov 04, 2009 | Computers & Internet
HP dv9000 screen shutdown
Power controller circuit on the motherboard needs repair by pro.
Oct 08, 2009 | HP Pavilion dv9000z Notebook
Tecra M3 won't boot, hdd light comes on then off.
The hard disk can be installed in another computer, but it won't boot up and run unless the computer is the same make and model with the same devices as the previous computer.
If it is not then you need to do a fresh Windows install to get a working computer.
What you can do as an alternative is to install the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Jul 30, 2009 | Toshiba (K000823110) Motherboard
Computer automatically restarts after shuting down
Did you install the drivers for the motherboard already? If so check the connections from the power switch to the board which all should be on the bottom right of your mobo. I switched a + and - one time and it went into a infinite look of turning on and off = / Beyond that ASUS Customer support sucks and I would just try to RMA it and start over.
Feb 20, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
Start up
If the Computer In question is a PC Desktop computer a few issues. First power supply may be malfunctioning. Second check the the CPU fan inside computer is running and not full of dust when you turn it on. If it's dusty, get vacuum cleaner and clean it. Fans need to be able to work without overheating because CPU runs hot.
Thirdly try to take out battery and restart computer. If starts up replace with new battery.
In Case it's a laptop. Take out battery and try to run using power supply and if turns on place battery back in. If battery isn't charging you will need a new battery. Let me know how you go!
Aug 03, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
