Question about Hilti Drills
My tool is Hilti TE708-AVR not working how I know to open the safety code and check the switch ?
5 Suggested Answers
SOURCE: i need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
Posted on Jun 09, 2009
smjdragonfly
  • 79 Answers
SOURCE: Hilti 905 avr starts up slow and uneven speed.
Some of them typically to start up slow. Less wear on the motor. Also make sure you're not using too much drop cord. No more than 100 ft 12/3. May be the brushes if you've had it for awhile. Please rate me
Posted on Jun 18, 2009
SOURCE: Need Brushes For Hilti TE905 AVR
Knighton Tool Supplies do Hilti brushes -
www.knighton-tools.co.uk
Posted on Apr 29, 2010
  • 90 Answers
SOURCE: Hilti-284228-rw-98091-163317
to my knowledge you have to send it to a hilti service center. you can't buy parts nor can a local shop buy parts for them. you may just have a loose wire or the switch you move to change direction may have come loose inside.
Posted on Sep 01, 2010
I need a control module for a hilti te.70.120v. If you have one or know someone who has l, please let me know.
No parts here and no connections other than a Google search which I assume you have already done.
Sep 28, 2016 | Hilti 120-Volt SDS Max Demolition Hammer...
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Diagram of hilti te1000 avr
You'll have to call Hilti for that. They're very protective of their material. But I think they'll still fax you a schematic.
Nov 17, 2011 | Hilti TE 1000-AVR Demolition Hammer...
From where can i buy a switch for my hilti sf 121a
Under Hilti, the SF 121 is the battey part number. I would need the tool's part number to know which switch you need. On the bad side, I haven't been able to find a secondary market for Hilti parts, you usually have to buy from them. Hilti's number is (866) 445-8827 if you would like to call them and order the part.
Aug 23, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Apr 13, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Hitli te 905 avr. light is on. any idea what it
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 16, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
My hilti te 6-s stopped working trigger looks to be ok. wondering how to test trigger and motor to be sure niether is the issue. thnx
I would first check the cord to the switch and then the 2 wires coming from the motor to the switch to see if they have continuity. UNPLUG tool first. to be on the safe side remove the bottom cover 2 T15 Torx screws and look at the brushes also and while apart if you have compressed air blow thru all the openings. The switch is hard to check so I would check everything around it first and if OK I would say a bad switch.
Apr 07, 2009 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
I need wiring schematics for hilti te 905 avr
Mar 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
82 people viewed this question
Top Hilti Drills Experts
John Trevino
Marvin
Marvin
woodzowl307
Are you a Hilti Drill Expert? Answer questions, earn points and help others
