Lg lsu242he a/c runs fine but when unit is in heating cycle ,the fan wont stay on.fan came on a split second then cut off.outdoor runs fine in both heat and cool.LCD seems like it is fluttering in this mode as well.checked defrost sensors and they both are open.
  • 12,061 Answers
Hi, whenever this type of problem is exhibited, usually we suspect the thermostat itself, as this is what ultimately controls the fan.
It still maybe a sensor, (the ONLY way to tell is by substitution with a "Known Good") although it is doubtful, I would more suspect the actual "Brain" of the unit.
Of course it also may be the actual fan itself, but again unlikely,however it still must be tested, usually they are 12 V DC fans, and so can be tested with a battery, all we are looking for is that it actually rotates, and doesn't stop unless voltage removed.
The LCD "Fluttering" does indicate that there also? maybe a fault with the power supply? This too needs to be checked for AC ripple, as well as "other" potential issues with the PSU, as this is, also, what may cause the LCD to "Flutter".
To do any sort of DIY one simply must obtain a service manual for the unit. It is almost impossible to undertake repair work, without one,if only for the spare parts numbers required to obtain spare parts.
Usually, I recommend that one engage the services of a professional, this will ultimately save one time and money, and perhaps hours of frustration too?
What I usually advise is to ask for a "Quote" this way at the least one can then make an informed decision as to what to do, repair or replace, as often seemingly simple problems can turn into expensive repairs.
Customers often tell me that they would rather put any monies that were to be spent on repair towards a NEW unit, with a full warranty, as cost to repair can often be as much as a new unit?..
Posted on Mar 22, 2011
Air conditioner fan wont start
change run capacirotor of outdoor fan motor.
Jan 07, 2014 | LG LSC121PMA Split System Air Conditioner
My LG mini split want cut off. I can cut it off on the unit but it still runs wide open it will not cut off by the remote either. any help appreciated.
This sounds like a faulty thermostat (indoor unit), or a welded (shut) set of contacts in the condensing unit (outdoor unit)
Aug 09, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
When calling for heat the outdoor unit fan cuts off and the compressor stays running after about forty seconds.
Actually, for heating mode, the condenser fan works on pressure build up by Fan pressure Switch. If pressure less the fan won't run.
Dec 08, 2010 | LG Art Cool LA181CNW Split System Air...
I have a honeywell Design Air reverse cycle aircondton system. Two weeks back it stopped working. When I switch it on it starts the system. The air is flowing but it is not cooling. what could be wrong and...
Hi, Just to to let you know, I am a contractor for heating and air conditioning. You have a split system heat pump it sounds like to me. If you have the indoor unit and an outdoor unit, this is a split. If the blower is running but not getting cold air, there could be several problems that would cause this. The service tech should be able to troubleshoot and find the problem in 1 hour or less. Depending on who you call, you are looking at anywhere from $65.00 to $85.00 per hour. Some places also charge you a travel or truck charge of $20.00, try and stay away from them. It will be a 1 hour minimum and in 1/4 hours there after. It could be a quick fix, breaker, fuse, or a serious problem as a compressor. This is what you are looking at. If you do have a split system and the outdoor unit is not on, check the breakers and fuses before you call any one. This may save you many $$$$$!! If you have a system that is all in one or a package unit and the blower comes on, make sure the outdoor fan is running ( condenser fan motor ) and listen to see if you can hear the compressor running. If you do have a split unit, go to the outdoor unit and see if the fan is running and compressor also. If not, check you're power supply. You may get lucky.
Sincerely,
Shastalaker7
Feb 12, 2010 | Heating & Cooling
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
Does not heat - compressor switches on/off repeatedly
check outdoor fan if running. the outdoor coil will freeze up on heat cycle. or outdoor board if there is one is defective.it could be reversing valve as well
May 18, 2009 | Heating & Cooling
Lsu242he mini split heat pump fluttering light
This sounds like a low voltage short in the unit. Low voltage shorts can be very difficult to troubleshoot. If you are serviceing the unit for a customer, it might be more cost effective to replace it.
Mar 20, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
