My computer keeps saying after i done a system recovery that the ntldr is compressed and i cant go anyfarther it keeps say restart
  • 822 Answers
Need to reinstall windows.............
could connect drive to other pc or lappy then try coppying ntldr to system.,...........
cheers
Posted on Mar 22, 2011
Ntldr compressed
You cannot do a recovery. Use the drive as a second drive in the computer and see if you can open the files systems and capture the data still hidden on the drive. Purchase a less expensive $30 hard drive and put a new Win 10 operating system on it. Once the OS has been established, you can access the second XP OS drive and search for material still intact.
Feb 05, 2018 | Computers & Internet
NTLDR is compressed
u need to reinstall your OS with the same Key that your pc came with
Oct 08, 2012 | eMachines eMachine w3502 512MB DDR PC-3200...
Dyche is compressed
have never heard of this term before however to decrompress
Decompress by using 'attrib' command on NTLDR
The NTLDR file must be altered in order to clear this error and correctly boot.
Boot into the Recovery Console (Need help with this? See this article:
Three Ways To Get Into Recovery Console)
When the console asks you to choose a Windows install to work with, enter 1 and press Enter
When prompted, enter your Administrator password
At the command prompt, enter the following commands, pressing Enter after each:
cd \
attrib -c c:\ntldr
exit
Restart your computer and the error should be gone - you can restart by typing Exit and pressing Enter.
hope this helps
Aug 29, 2012 | Computers & Internet
Restored Emachine T3516 computer to factory settings and now the computer says the ntldr is compressed
This should solve your problem:
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows XP compact disc (CD). To do this, follow these steps:
a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When prompted, type the Administrator password.
2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
4. Type "map" (without the quotation marks), and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\ntldr._ <ENTER>
Note the underscore character after the "."
The following message appears: ntldr, 1 file(s) expanded.
7. Type "exit" (without the quotation marks). The computer restarts.
8. Remove the Windows XP CD and start the computer normally.
IF that fails put in your Windows installation CD and reinstall the operating system
Aug 27, 2011 | eMachines T3516 PC Desktop
Ntldr is compressed
An NTLDR is compressed error is pretty easy to fix(much better then NTLDR is missing errors!).
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Feb 25, 2010 | Microsoft Windows XP Home Edition
How can I decompress the NTLDR on my computer? My computer just shut off and when I turned it back on the screen said ....NTLDR is compressed. Press Ctrl + Alt + Del to restart. I have done that and it...
It sounds like the Operating System start up files are damaged. If NTLDR is corrupted then you will need to run the OS installation disc and try to repair the Windows installation. If the repair does not work you may need to re-install the operating system using the installation disc that came with your computer.
Oct 29, 2009 | Computers & Internet
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
Dell computer running windows xp will not boot. NTLDR compressed
best thing to do if you can get one is a propper install disk and then follow these instructions..
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows Xp compact disc (CD). To do this, follow these steps:
Jul 07, 2009 | Compaq Presario 4090US (470016-303) PC...
I have a emachines w 3107 I tried to use the system recoverey disk. I went through the whole process, Then when it re boots a error says NTLDR is compressed press alr cont del , And I get the same error...
5. Now you should be at the command prompt and ready to repair the ntldr file!
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | E-Machines eMachines Desktop PC
NTLDR compressed
Try the following
Insert the Windows XP bootable CD into the optical (CD or DVD) drive and restart the notebook.
When prompted to press any key to boot from the CD , press any key on the keyboard.
Once in the Welcome to Setup screen, press the R key to repair Windows.
Press the 1 key and then press Enter .
Type the Administrator password at the prompt.
Type the following commands in order
cd\
ren ntldr ntldr.old
expand d:\i386\ /f:ntldr
exit
Remember to press enter after every command
Now your computer will restart, and check if the problem cures
Nov 24, 2008 | Dell Precision M60 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
