Recently my printer stopped working. It does not turn more I took the service technician and he told me that maybe I needed to replace the logic board. Where can I Buy the logic board printer brand Canon MP630 model?
  • 41 Answers
My advise -- replace it.
The problem is that by the time you add up the price of a new motherboard and the technican's labor
costs, it will exceed the replacement cost of a new printer. That is the sad truth about most inkjet printers.
They are generally cheap for a very good reason.
As to the motherboard replacement, you would have to contact Canon technical support for pricing. I
doubt that there is a generic replacement board.
Posted on Mar 22, 2011
I have a 50'vizio HDTV 20A, the tv was flashing than it just stopped working. Took to a repair shop they replaced the power supply. Told them about the flashing that was going on (edges of the objects on...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 13, 2017 | Vizio P50HDTV20A 50 in. Plasma HDTV
I HAD TO REPLACE THE COLOR CARTRIDGE CYAN. I BOUGHT A NEW ONE AND REPLACED IT CORRECTLY AND THE PRINTER STILL SAYS, CAN'T PRINT NEED CYAN. I HAVE TRIED ABOUT EVERYTHING I KNOW. I'VE SHUT IT OFF AND...
Dear friend,
There may be a problem wih the cartridge recognization chip or with the sensor cable or else logic board.Please check with the service centre for better.
Mar 11, 2011 | Office Equipment & Supplies
BB Bold 9000 wont turn on - red light is flashing. Its been charing for several hours now and still will not turn on. I've taken the battery out and put it back in, then charge it some more...still...
I' really sorry to tell you, but looks like your phone's logic board is out of work! It happened if mine BB 9000 two moths after the warranty expired! Took to a technician and I was told to replace the logic board! It was happen like this (http://www.youtube.com/watch?v=MGSRQb1Qb1Y) before it get out of order forever! Hope I have helped you! Just to you to know I tried just about everything that is on the net, and nothing worked!
Apr 20, 2010 | RIM BlackBerry Bold 9000 Smartphone
Get an error message" ,Printer error-See your documentation and call service if necessary
I found this on another forum because I had the same problem. This solved the problem and hopefully will solve this error message too.
Found this on techsupportforum.com and it worked for me. Good Luck!
Press and HOLD all following buttons: Power, Load/Eject (I don't have this button, so I skipped this), Stop, B&W, Color. Continue to hold the buttons until "Init Eeprom" appears on the printer screen. Press Color button to clear protection counter.
The panel then told me to press the power button, I did. When it came back up, everything was fine.
Dec 27, 2009 | Epson Stylus CX6400 All-In-One InkJet...
E42 Error
E 42 mean scanner error please service it by a technician
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Star logic monitor settings
I typically do capacitor replacement on lcds all the time insde, the board for power will most likely have 1 - 4 blown capacitors, replace these and the monitor should be good as new, btw 1 is a 10 v smallish size you can replace it with a 16 volt same MF.
Sep 10, 2008 | Star Logic 17" LCD Monitor
Printer not taking power.
since a local service has told u n u still want yr printer working i'll advice u to take it to some other service centre to look into it.
but the usual problem with yr model of printer not powering on normally is a s a result of the logic board being bad. once the logic board is being replaced yr printer should come up..
but be very sure yr problem is not from the adaptor that is i hope u have checked it and is working very well.
thank u
Jun 01, 2008 | HP DeskJet 3940 InkJet Photo Printer
Won't Print Any Ink
well? how old is your printer?. does your printer head is new?
reason why doesnt have printout:
1. the unit doesnt recognize the printer head:
solution: turn off the unit and turn it on again.
2. Defective logic board.
solution: replace logic board.
3. Defective printer head
solution: replace printer head
4. Clog printer head
solution: wash the printer head with water..make sure to dry
before you install it to the printer.
5. Defective purge unit.
solution: replace purge unit.maybe it wont suck ink because of the loose or broken springs under caping of the purge unit..
6. inktank.
solution: check the lips of inktank maybe it much shallow so it
wont touch the nozzle of printer head..
you need to cut the edge of the lips of inktank so it will touch
the nozzle of the printer head.
Dec 08, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board.
Dec 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Error code
The other possibility is that the grease on the Carriage is too viscous.... had the same problem with two separate printers... there is a service bulletin which suggests that the grease needs to be replaced at a service center. When I read about the problem I slid the carraige back and forth along its track several times and the error lite dissapeared and printer is working well, so far (3 days)
Dec 12, 2006 | Canon Pixma MP500 All-In-One InkJet...
83 people viewed this question
k24674
jasbo
jasbo
